Nordisk Musik
Posted: Sat Jun 30, 2007 8:20 am Post subject:
NL2 patches on my 2x |
For some time I have experimented with decent trancesounds on my 2x, but I didn't get the result I wanted. Some introduced me to synthdesign.com where I downloaded 40 patches. The format is mid but I couldn't load them into my 2x. Has somebody else tried precisely this file? I even tried with the factory presets from clavia, to be sure that all MIDI setup was correct. I has no problems loading the factory pacthes, this just didn't work.
http://www.synthdesign.de/claviaNL2.htm Last edited by Nordisk Musik on Sat Jun 30, 2007 2:41 pm; edited 1 time in total |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sat Jun 30, 2007 10:53 am Post subject:
As far as I know the file is *.rar so is it Midi?
If you send me the files, I can try to open them.
I'll PM you about details
Wout |
Nordisk Musik
Posted: Sat Jun 30, 2007 11:17 am Post subject:
The file is a typical .MID file that contains 40 patches. I don't really have any idea what bank it is overwriting as the file is written for the standard NL2.
Normally when you play a .MID file to import patches, you can see the whole bank is being scrolled through. This doesn't happen with this file and no new sounds. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sat Jun 30, 2007 12:12 pm Post subject:
Well, the first question... Are you on PC or Mac?
Wout |
Wout Blommers
Audio files: 123
G2 patch files: 12
Nordisk Musik
Posted: Sat Jun 30, 2007 2:28 pm Post subject:
| Cool! thanks a lot for the help I appreciate it, I'll check this ASAP. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Jul 01, 2007 3:24 am Post subject:
Nordisk Musik, you downloaded and opened the file from that site. Maybe I'm missing something, but the *.rar file asks for StuffIt, which converts it into *.sit, which I can't open. How do you did it ?
Wout |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Jul 01, 2007 5:53 am Post subject:
I've played a little bit with some files...
I send the SysEx of the program and a midi file, because I think mp3 is as terrible as possible to listen to...
Set the Unison at 9 [Shift + 3 times Sys, program cursor to 9] to get the effect.
Midi 180 bpm.
Wout
 Download (listen) |
| Filename: |
Stice-Xperiance11-Digeridoo.syx |
139 Bytes |
| Downloaded: |
417 Time(s) |
 Download (listen) |
| Filename: |
Chords11.mid |
2.28 KB |
| Downloaded: |
405 Time(s) |
Nordisk Musik
Posted: Sun Jul 01, 2007 7:46 am Post subject:
| yes I simply just draw the .MID file from the .RAR folder without getting any messages. Thanks for helping once again I'll look into this, I never really understood the unison option on this synth. I don't think any specific unison value is saved when writting a patch. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Jul 01, 2007 12:43 pm Post subject:
| Nordisk Musik wrote: | | yes I simply just draw the .MID file from the .RAR folder without getting any messages. |
Could you do this too for the NordLead3 files on that site and send me the midi? I would be grateful!
| Quote: | | Thanks for helping once again I'll look into this, I never really understood the unison option on this synth. I don't think any specific unison value is saved when writting a patch. |
Mostly I use the Unison set to 1, which means only a stereo sound with a slight delay, because that detuned sound isn't always nice When I use Unison to be detuned I use 5, but mostly 9, which gives the effect the most.
Indeed, Unison is a global effect, to all the Slots and stays the same until changed. The NordLead3 has the ability to save the Unison in the Patch and therefor use different Unison in a Performance (Unison has it's own DSP, so the Voices per Slot stay the same)
Wout |
cappy2112
Joined: Dec 24, 2004 Posts: 2500 Location: San Jose, California
Posted: Fri Jul 13, 2007 11:57 am Post subject:
| Wout Blommers wrote: | As far as I know the file is *.rar so is it Midi?
Wout |
.RAR files are compressed files like .ZIP. They use a Russian compression tool called WinRar, but I think recent versions of Winzi will uncompress .rar files. If not, you can get a short-trem version of Winrar from the winrar website.
As far as what's inside the .rar file, who knows. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Fri Jul 13, 2007 1:04 pm Post subject:
| cappy2112 wrote: | | .RAR files are compressed files like .ZIP. They use a Russian compression tool called WinRar, but I think recent versions of Winzi will uncompress .rar files. If not, you can get a short-trem version of Winrar from the winrar website. | Yep, it works!
Wout |
