 Forum index » Clavia Nord Modular » G2 Performances - Completed
delay noodle - 04-012-006
Page 1 of 1 [9 Posts]
Audio files: 299
PostPosted: Sat May 29, 2004 7:18 am    Post subject: delay noodle - 04-012-006 Reply with quote  Mark this post and the followings unread
Some experiments with delays, shape LFO's and frequency shifting.
Jan.
04-012-006.prf2
 Filename:  04-012-006.prf2
 Filesize:  10.75 KB
 Downloaded:  3439 Time(s)
Audio files: 231
PostPosted: Sat May 29, 2004 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Another great one, Jan.
It has a classic electronic music quality to it. It goes though some great changes.
I usually put up a bunch of emoticons at this point, but I'll refrain out of respect to you're not being into them.
Audio files: 299
PostPosted: Sat May 29, 2004 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Howard.
It's one of the nice surprises of the G2 that it is capable to make some sound types that were present in the old time electronics (and that I've for a long time wondered about how to do it).
Jan.
Audio files: 231
PostPosted: Sat May 29, 2004 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I recorded a few minutes of this one and I'm posting it as an mp3. This is just a "naked" recording right out of the G2 - no processing, gain riding, compression, or reverb. Too bad the LAME mp3 encoder has mangled and muddied the audio. This recording is just to let people see what the noodle "sounds like".
Jan. If you don't care for me doing this, please let me know and I'll take it down.
Punter-04-012-006-5.mp3
Jan Punters G2 Noodle 04-012-006-5
96 kbs mp3 (this encoding muddies the sound considerably)
 Filename:  Punter-04-012-006-5.mp3
 Filesize:  2.52 MB
 Downloaded:  2836 Time(s)
Audio files: 231
PostPosted: Sat May 29, 2004 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's the same recording at 192 kbs...
Punter-04-012-006-5--192k.mp3
The same as the previous recording but at 192k with LAME encoder
 Filename:  Punter-04-012-006-5--192k.mp3
 Filesize:  5.04 MB
 Downloaded:  2780 Time(s)
Tim Kleinert
G2 patch files: 236
PostPosted: Sat May 29, 2004 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow. It's so multifaceted, it almost sounds like a modern composition.
Big up for Jan again. thumleft
Audio files: 299
PostPosted: Sat May 29, 2004 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
mosc wrote:
I Too bad the LAME mp3 encoder has mangled and muddied the audio. This recording is just to let people see what the noodle "sounds like".
Is it the LAME encoder or is it related to the sounds in the noodle somehow ? Is one sound better 'encodable' than another, or ?
I use the LAME encoder to rip CDs to my laptop sometimes and didn't really notice it to be particularry bad for the job.
No no, it's OK, thanks (I like 'm all to suffer, having G2's or not :-)
Jan.
Audio files: 231
PostPosted: Sat May 29, 2004 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
The different encoders do better on some sounds than others. If the sound is complex the encoders seem to "steal" from the high frequencies and from the stereo separation. So, if there is a lot of complex high frequency stuff with subtile phase shifting in stereo, the encoding isn't going to work that well. The 192 kbs is much better than the 96 kbs, or whatever.
Back to the noodle. Yes, this IS a real modern composition. This is a process composition in the style that was big in the 60s with John Cage, Robert Ashley, and the people from the ONCE Festivals (and others). The fact that the details of the music are automatically generated isn't significant, at least to me. The composer creates the sounds and controls the extent and bounderies of all of the parameters.
This is as much composition as kinetic sculpture is art.
One thing that seems to inhibit many people from considering these self-playing patches as "real" compositions is the indeterminacy of the duration. If one adds a little circuit where you push a button to start the noodle and it ends after some predetermined time, then these patches seem to many more acceptable as compositions. I guess our concept of composition has expanded over the years, but we still cling to the essentiality a beginning and an ending.
Audio files: 299
PostPosted: Sat May 29, 2004 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, seems logical.
A good noodle should at least aim to blur the distinction between man and machine :-)
I think you're right and I guess that's why I started http://electro-music.com/forum/topic-2191.html as a structure to embed noodles in.
Unfortunately it seems a bit larger than the G2 can currently handle, that's why I didn't really get on with it ... I ran into trouble on adding content. Some of the paches I embedded wouldn't accept LFOs any more while this should still be posible, resource wise. Even worse, such a patch would then stop all other patches as well.
I hope to able to continue this one day, to be able to blur the distinction mentioned above a bit further.
BTW the bug known to Clavia.
Jan.
