u_o
Posted: Thu Sep 04, 2008 1:46 pm Post subject:
nord wave and midi?? Subject description: how i work with midi? |
can i work with midi and the synte?
i want to edit with midi you know..
or this is just record?? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Sep 04, 2008 2:36 pm Post subject:
Just short...
Musical Instrument Digital Interface is a way to communicate between synthesizers and computers. In one of the instruments there is a Midi Out connection to the second instrument connected by the Midi In. In sucg a configuration instrument two is played by the first one. This can be the computer, using a program which can send Note On and Note Off commands, Volume commands, Note duration commands, and so on. Such a program is mostly called 'sequencer'.
Wout |
u_o
Posted: Thu Sep 04, 2008 2:59 pm Post subject:
you dont anderstend me i want its play like vst to edit my melodys
i cannot edit like midi with wav file |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Sep 04, 2008 3:15 pm Post subject:
Well, the syntax of your English writing is a little to vague to detect the question... No offence, BTW!
What is it you want to edit...?
The sound of the synth or the notes in the song?
Wout |
u_o
Posted: Thu Sep 04, 2008 3:30 pm Post subject:
sorry about my english i lern it alone with the time...
i want to edit The sound of the synth like vst on midi chanel
then i do export you know.. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Sep 04, 2008 10:03 pm Post subject:
| u_o wrote: | | sorry about my english i lern it alone with the time... | Take your time to write a message. Using SpellCheck and a Hebrew-English dictionary will help for sure. | Quote: | | i want to edit The sound of the synth like vst on midi chanel then i do export you know.. | There is no Editor to the Wave published yet; the Clavia WaveEditor is a kind of librarian and can't be used to change the parameters.
Changing the parameters along with the son is done by recording the movements of the knobs in CuBase or a alike sequencer. To manipulate the synth soundwise use the knobs...
Wout |
u_o
Posted: Fri Sep 05, 2008 5:10 am Post subject:
one more question
how i am save the sounds i make? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Fri Sep 05, 2008 8:36 am Post subject:
| Manual Clavia Wave on Page 15 wrote: | Storing a Program
To store a Program without changing Program name or category:
Press the store button.
The Store button LED starts flashing, and the Program location is shown in the LCD window.
Press SLOT A or SLOT B buttons at any time to cancel the procedure.
Select a location.
Use the Program buttons or the LCD-dial to choose a Program location.
Press the store button to confirm.
The selected Program is overwritten. |
Wout  |
