Patch corrupt after save
Page 1 of 1 [10 Posts]
torsig1967
PostPosted: Mon Sep 22, 2008 2:31 pm    Post subject: Patch corrupt after save
Subject description: Saving using the synth corrputs patches sometimes
Is this a known bug?
I only get this when working soley on the hardware. Editor = no problem.
- I'm saving a patch and when trying to find a sutiable storage location I "pass" a memory area (turning the rotary dial) with unused patches.
- After this "passage" all patches will be labeled "Unused" in the display. Even if they are occupied. Storing after this has happened will give either of two results:
1. If the location was indeed empty, patch is stored ok.
2. If the location was occupied the newly stored patch gets corrupt and can not be recalled.
Anyone else seen this?
Audio files: 297
PostPosted: Mon Sep 22, 2008 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, this is a known bug, you can't have gaps in the storage.
torsig1967
PostPosted: Mon Sep 22, 2008 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's what I suspected.
So downgrading/upgrading system (and thus resetting memory) is of no use? I found an old thread suggesting this.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Sep 23, 2008 3:06 am    Post subject: Reply with quote  Mark this post and the followings unread
I have the same problem...
I will try. Girst have to find a V3.03 version, somewhere on my computer Smile
Wout
torsig1967
PostPosted: Tue Sep 23, 2008 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is this happening to ALL NM1 owners or just some unlucky guys like Wout Blommers and me?
Let me know what happens Wout...
I don't have Mac Classic so I can't do the upgrade/downgrade without a lot of trouble.
Audio files: 297
PostPosted: Tue Sep 23, 2008 2:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wasn't there a trick with uploading a pchlist to the synth thinking ... it involved making an actual blank patch for the empty locations IIRC ...
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Sep 23, 2008 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
torsig1967 wrote:
... Wout Blommers lot of trouble. ...
I hope you created the bold text because you copy/pasted from the header Wink
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Sep 23, 2008 3:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think it was used to empty the memory or something like that. Mainly used when selling the synth without Patches.
Wout
torsig1967
PostPosted: Wed Sep 24, 2008 5:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Well I tried making a bank with only one patch and downloaded to synth to clear all other patches in a bank. But that didn't help, or maybe it even started my memory trouble I'm not sure.
Anyway, to fill a bank with minimal dummypatches (so there are no gaps) I created a folder with 99 patches and used the download from folder option in the editor. As long as I stick to this I have no problems but 99 dummies makes the browser less useful.
gentlclockdivider
PostPosted: Thu Apr 09, 2009 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
yep same problem here
Really annoying....
