torsig1967
Posted: Mon Sep 22, 2008 2:31 pm Post subject:
Patch corrupt after save Subject description: Saving using the synth corrputs patches sometimes |
Is this a known bug?
I only get this when working soley on the hardware. Editor = no problem.
- I'm saving a patch and when trying to find a sutiable storage location I "pass" a memory area (turning the rotary dial) with unused patches.
- After this "passage" all patches will be labeled "Unused" in the display. Even if they are occupied. Storing after this has happened will give either of two results:
1. If the location was indeed empty, patch is stored ok.
2. If the location was occupied the newly stored patch gets corrupt and can not be recalled.
Anyone else seen this? |
Joined: Apr 03, 2004 Posts: 24452 Location: The Netherlands, Enschede
Audio files: 297
Posted: Mon Sep 22, 2008 2:43 pm Post subject:
Yes, this is a known bug, you can't have gaps in the storage. _________________ Jan
torsig1967
Posted: Mon Sep 22, 2008 3:10 pm Post subject:
That's what I suspected.
So downgrading/upgrading system (and thus resetting memory) is of no use? I found an old thread suggesting this. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Tue Sep 23, 2008 3:06 am Post subject:
torsig1967 wrote: | That's what I suspected.
So downgrading/upgrading system (and thus resetting memory) is of no use? I found an old thread suggesting this. | I have the same problem...
I will try. Girst have to find a V3.03 version, somewhere on my computer
Wout |
torsig1967
Posted: Tue Sep 23, 2008 2:27 pm Post subject:
Is this happening to ALL NM1 owners or just some unlucky guys like Wout Blommers and me?
Let me know what happens Wout...
I don't have Mac Classic so I can't do the upgrade/downgrade without a lot of trouble. |
Audio files: 297
Posted: Tue Sep 23, 2008 2:39 pm Post subject:
Wasn't there a trick with uploading a pchlist to the synth ... it involved making an actual blank patch for the empty locations IIRC ... _________________ Jan
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Tue Sep 23, 2008 3:29 pm Post subject:
torsig1967 wrote: | ... Wout Blommers lot of trouble. ... | I hope you created the bold text because you copy/pasted from the header
Wout |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Tue Sep 23, 2008 3:30 pm Post subject:
Blue Hell wrote: | Wasn't there a trick with uploading a pchlist to the synth ... it involved making an actual blank patch for the empty locations IIRC ... | I think it was used to empty the memory or something like that. Mainly used when selling the synth without Patches.
Wout |
torsig1967
Posted: Wed Sep 24, 2008 5:52 am Post subject:
Well I tried making a bank with only one patch and downloaded to synth to clear all other patches in a bank. But that didn't help, or maybe it even started my memory trouble I'm not sure.
Anyway, to fill a bank with minimal dummypatches (so there are no gaps) I created a folder with 99 patches and used the download from folder option in the editor. As long as I stick to this I have no problems but 99 dummies makes the browser less useful. |
gentlclockdivider
Posted: Thu Apr 09, 2009 12:29 pm Post subject:
yep same problem here
Really annoying.... |
