 Forum index » Clavia Nord Modular » G2 Performances - Completed
some grainy madness
Page 1 of 1 [6 Posts]
Audio files: 297
PostPosted: Sat Aug 07, 2004 9:10 am    Post subject: some grainy madness Reply with quote  Mark this post and the followings unread
some grainy madness using Rob's granulizer & some other stuff.
Jan.
04-013-009.prf2
granular madness, a noodle
 Filename:  04-013-009.prf2
 Filesize:  16.68 KB
 Downloaded:  3167 Time(s)
Audio files: 224
PostPosted: Sat Aug 07, 2004 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Wild!!!
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sat Aug 07, 2004 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Brilliant!
Rix
G2 patch files: 25
PostPosted: Wed Aug 11, 2004 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awesome!!
W.T.
G2 patch files: 11
PostPosted: Thu Aug 19, 2004 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
super afro
Audio files: 297
PostPosted: Sat Aug 21, 2004 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I told you it was madness :-)
Now this performance and about 20 others (some posted, some not, maybe more later) will end up in the noodle radio, which curentlly looks like below.
The small PCB on top of the trash is the custom MIDI controller I built for channel selects and volume control. De us-122 on the left is not part of the project.
The black box needs some more painting, some of the patches need a little more work and then all the stuff in front of the black box will go into the box which will then hopefully be kind of mysterious having two knobs without explanation.
(As you can't try : one is volume, the other is the 'Bengt knob', when you turn it beautifull sounds are made and when you don't turn it beautifull sounds are made as well)
Jan.
 Filesize:  116.63 KB
 Viewed:  12142 Time(s)
