 Forum index » News... » Gear News
STEIM is happy to announce junXion version 4
Page 1 of 1 [2 Posts]
Audio files: 235
PostPosted: Fri Dec 19, 2008 11:26 am    Post subject:  STEIM is happy to announce junXion version 4 Reply with quote  Mark this post and the followings unread
STEIM is happy to announce junXion version 4!
Just in time for those cold wintermonths (for us Northernhemispherians) when all you want to do is play with your gamecontrollers and your new videocamera;) Besides the already available Wiimote support, junXion v4 now also includes videotracking and Arduino support. You can read the full story below and more on http://www.steim.org/steim/junxion_v4.html .
junXion v4 is a Mac OSX data routing application that can process 'sensors' from any HID (joysticks, mice, touchscreens), MIDI, OSC, Audio, Arduino and Video device using conditional processing and remapping, with MIDI or OSC events as its output. This resulting MIDI or OSC data is then available to any audio or music software that runs on that Mac or can be send to external MIDI/OSC devices.
junXion v4 is a system whereby the user creates so-called 'Patches'. Each Patch is a connection between a sensor input (for example: 'joystick X-axis' or Video Event Object y-position) and an Action (for example: 'convert the sensor data into midi controller 3, but only under certain conditions'). The Action is a user selectable set of conditions and actions that determine what should happen with the input-sensor's data and what kind of MIDI or OSC data should be send out.
NEW features for v4 (compared to v3.2):
* better support for OSC Input messages with easy learning function
* improved user interface
* Arduino sensorboard support
* live Video Input image tracking
buzzr
PostPosted: Fri Jan 23, 2009 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I wish they would release a new version of LiSa. Since Michel died I doubt that will ever happen now Sad
