Transpose midi data on Modular Key?
Page 1 of 1 [3 Posts]
torsig1967
PostPosted: Sun Jan 11, 2009 7:34 am    Post subject: Transpose midi data on Modular Key? Reply with quote  Mark this post and the followings unread
If I send midi data to the midi in port is there some way to interactively transpose this using the internal keyboard?
torsig1967
PostPosted: Thu Jan 29, 2009 2:19 pm    Post subject: Re: Transpose midi data on Modular Key? Reply with quote  Mark this post and the followings unread
I'll rephrase this question like this:
Is there any way to distinguish incoming midi-note data on the active slot channel from keyboard action on the internal keyboard?
torsig1967
PostPosted: Thu Jan 29, 2009 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is kind of a solution to my problem.
It has some limitations though...
Anyway, the idea with this Polyphonic Transpose is this.
Feed the NM1 with midi from a midi sequencer.
Use the NM1 to transpose the notes.
IMPORTANT!
- Intended for NM1 Key
- Oct Shift must be set to -2 on NM1.
- Middle C = No Transpose.
- No midi-in below C#3 will be played (they'll transpose), to play low notes transpose inside the patch with "NOTE OFFSET".
Midi in will be transposed by the internal keyboard with this patch.
 Filesize:  311.38 KB
 Viewed:  181 Time(s)
PolyTranspose.pch
 Filename:  PolyTranspose.pch
 Filesize:  1.57 KB
 Downloaded:  147 Time(s)
