 Forum index » Clavia Nord Modular » G2 Patches - Completed » Sequencer - interactive
SpaceGenA
Page 1 of 1 [3 Posts]
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Tue Sep 14, 2004 8:52 pm    Post subject: SpaceGenA Reply with quote  Mark this post and the followings unread
It had to happen... a noodle based on the reverb patches. This one is based on experiments with information contained in the Ursa Major Space Station manual. Unfortunately I couldn't put in 8 taps and the feedback taps, so I had to make do with 6 taps + 2 feedback taps and scale the delay times.
2 parameters to note on the front panel: SpaceGen randomly generates a new reverb/delay patch and LineGen generates a new riff to play.
I ran out of resources so I couldn't get it to randomly select feedback and reverb level settings, but they're kinda fun to play with anyway... I spose, heh. Enjoy...
edit: Patch fixed
Noodleverb.pch2
Interactive noodle vaguely based on the Ursa Major Space Station specs...
 Filename:  Noodleverb.pch2
 Filesize:  5.69 KB
 Downloaded:  2206 Time(s)
Fozzie
G2 patch files: 49
PostPosted: Tue Sep 14, 2004 11:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can't play the patch right now, as I don't have my engine hooked up, but I can't figure this one out:
why do you use the SpaceGen module without a random input of some sort? It now seems to send the '64' value through logic delays and s/h modules everytime you press it. What am I missing?
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Tue Sep 14, 2004 11:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
The switch triggers the sample and hold modules (by sending a pulse of 64 units followed by 0 units, same as a logic pulse) which each grab a value from the random LFO. The logic delay's are there to ensure that each s+h gets a different value from the LFO.
Now that I look at it, I have made a mistake. The random LFO is set way too slowly to set widely varying times for each delay Embarassed. Thanks Fozzie, should be fixed now.
