 Forum index » Clavia Nord Modular » G2 Patches - Completed » Synth
Copy Cat
Page 1 of 1 [4 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Sep 29, 2004 8:04 pm    Post subject: Copy Cat Reply with quote  Mark this post and the followings unread
This is an analogue mono-synthesiser based on the Octave Cat (late 70's). The original had a modulation system based on a pair of 3 way source switches and level knobs for each of VCO1, 2 and VCF. This made for a compact 'playable' front panel which still had a lot of modulation options. It did however prevent you from, for example, modulating the Filter frequency with both the ADSR & VCO1. I have taken the liberty of using an 8 way mixer for each of the three mod destinations instead (implementing the exact switch arrangement takes about 10% more resources for no benefit). Apart from that, the architecture is followed quite faithfully with simultaneous mixable waveforms, sync, xmod, re-trigger ADSR etc.
The PWM gets a few more mod sources, the original sine LFO or DC annoyed the hell out of me. The AR envelope can be switched to an AD type, another harmless improvement.
If your stuck without an editor, this one is quite good just to tweak from the front panel. Use the parameter overview tool to see where all the controls are located or just explore.
pusseySRM.pch2
copy of cat SRM
 Filename:  pusseySRM.pch2
 Filesize:  3.59 KB
 Downloaded:  2094 Time(s)
Audio files: 227
PostPosted: Wed Sep 29, 2004 9:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I never hat a CAT, and really just learned about them recently, but they seem like an excellent little synth. This is a nice patch. Lots of flexibility without changing cords.
Roland Kuit
G2 patch files: 127
PostPosted: Thu Sep 30, 2004 3:05 am    Post subject: Cat Reply with quote  Mark this post and the followings unread
I 've decided to keep the Cat, and give 'r milk allready Wink
PostPosted: Thu Sep 30, 2004 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I love the CAT synths!
Flickr
