 Forum index » Clavia Nord Modular » G2 Performances - Experimental
Tape Loop
Page 1 of 1 [3 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri Nov 05, 2004 3:44 pm    Post subject: Tape Loop Reply with quote  Mark this post and the followings unread
Hi, just an experiment with old style, long delay, tape loop type effect.
Uses two 2.7 Sec in series, there is an allpass and pitch shifter in the feed back loop, as well as frequency shifter between the two delays.
The second delay is modulated very slightly with an LFO.
tapeloop2.prf2
 Filename:  tapeloop2.prf2
 Filesize:  6.4 KB
 Downloaded:  1755 Time(s)
Audio files: 224
PostPosted: Fri Nov 05, 2004 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice...
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Fri Nov 05, 2004 5:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like this a lot...one of those patches you can let the G2 play in the background indefinetly Very Happy
