syntacon vcf 2x9volt batteries
Page 1 of 1 [2 Posts]
synthesist
PostPosted: Fri Jul 08, 2011 6:59 am    Post subject: syntacon vcf 2x9volt batteries
Subject description: maybe it's just impossible
hey!
I spent the last 3 days working on a stripboard-synthacon VCF. I took the orignal design from CGS homepage though.
There is a pretty loud sound coming out, but somehow the Cutoff pot doestn work. The resonance pot doesnt change the sound a lot. The pot that should control the TL071 amp stage does boost the low frequencies instead of the whole loudness.
Anyways...
Before I try to fix this circuit again I need to know one thing: Is it actually possible to power the circuit by two 9 volt batteries without changing some values of the resistors and other components?
andrewF
PostPosted: Sun Jul 10, 2011 3:36 am    Post subject: Reply with quote  Mark this post and the followings unread
not exactly the same but Houshu made a 9V version of the Steiner
schematic here
be warned - his stuff ususally needs some taming tho
