Multiphase Ramp + Sine
Page 1 of 1 [2 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Apr 05, 2005 7:45 pm    Post subject: Multiphase Ramp + Sine Reply with quote  Mark this post and the followings unread
You often require multiple phase outputs for LFO waves, a couple of inbuilt LFO’s have sync and phase control, they suffer from the fact that the phase relationship is not set till after the 1st cycle completes and tend to be heavy-ish on DSP.
This building block first alters the phase of the input ramp (purple modules) then provides a sine shaped wave following the new phase. The sine converter came from IK’s work and in this case is missing the final “minus one” module because I typically want a positive only sine for controlling vca etc.
Handy for custom chorus etc or as demoed here, a grain type pitch shifter, adjust LFO rate for various effects.
multiphase.pch2
 Filename:  multiphase.pch2
 Filesize:  3.3 KB
 Downloaded:  2063 Time(s)
Audio files: 232
PostPosted: Tue Apr 05, 2005 9:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Ian. This is an amazing effect. There is a great deal I have learned from looking at this patch. Never thought of using the delay module like that. Cool
This is not just a building block, it's a great patch.
