Cheap 8 stage all pass filter for diy modification
Page 1 of 1 [3 Posts]
Steveg
PostPosted: Sat May 15, 2021 3:40 am    Post subject: Cheap 8 stage all pass filter for diy modification Reply with quote  Mark this post and the followings unread
I was trying to find information on diode based all pass filters when I bumped into this: https://www.czh-labs.com/products/audio-all-pass-filter-phase-rotator-module-board-md-a110-audiowind-a-110
For US$20 it seems a reasonable price ... being through hole construction it should be easily modifiable to add variable phasing with vactrols or diodes.
wakyct
Audio files: 12
PostPosted: Sat May 15, 2021 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the link, I thought the background info on it was interesting as well.
Steveg
PostPosted: Sat May 15, 2021 6:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I thought the explanation was not very clear. I think he is trying to say that if you have transients in your signal (possibly due to interference) you can use the APF to smear the different frequency components of the transient to reduce its audibility. But then again he may be suggesting that the "leading phase" APF can be used to compensate for phase shifts caused by low pass filters. Or maybe both ... or maybe something else entirely.
