Jurgen's Bergfors VCA build - DIY beginner needs help
Page 1 of 1 [16 Posts]
jurekprzezdziecki
PostPosted: Tue May 10, 2016 1:55 am    Post subject: Jurgen's Bergfors VCA build - DIY beginner needs help Reply with quote  Mark this post and the followings unread
guys,
i have found a single VCA circuit which is Jurgen's Bergfors design.
it looks simple and sounds very good as a description says.
http://hem.bredband.net/bersyn/VCA/lm13600%20vca%202.htm
i have put this into Eagle for further PCB design. i would ask you to check if i made some mistakes - it's my first schematics in Eagle... so it was hard;Smile
there is no voltage values on the original schematics so i put +/-12V.
i have used LM13600 as an original but i know that 13700 could be used as well.
ther are power rails outside the IC - i don't know what voltage shoud be used - i put bipolar +/-12V as well.
also... this circuit uses only a half of LM13600 - so what to do with a second part of the LM13600? it's just unconnected? should be grounded?
i have chosen a standard 3,5 mm mono jacks... just for something on the PCB. i think the best would solder them with wires to the board separately.
when all errors will be removed i will put it on breadboard:)
 Filesize:  15.35 KB
 Viewed:  266 Time(s)
PostPosted: Tue May 10, 2016 2:08 am    Post subject: Re: Jurgen's Bergfors VCA build - DIY beginner needs help Reply with quote  Mark this post and the followings unread
I'd say use the second half for a second VCA Smile
jurekprzezdziecki
PostPosted: Tue May 10, 2016 2:10 am    Post subject: Re: Jurgen's Bergfors VCA build - DIY beginner needs help Reply with quote  Mark this post and the followings unread
thanks for your replay. i don't want to make it to complex, it's my first project Smile
do you mean to make a second channel of this VCA?
LFLab
PostPosted: Tue May 10, 2016 6:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Nope, a second VCA (was my suggestion on Muffs as well Very Happy ).
wackelpeter
Audio files: 10
PostPosted: Tue May 10, 2016 6:25 am    Post subject: Reply with quote  Mark this post and the followings unread
i'm not sure if i did build it correct or wrong nearly 2 years ago, but i wasn't able to mute the signal totally... it was almost present and with some CV it got amplified more...
maybe try this on breadboard first... i've exchanged mine with 2 others VCA's...
But as i said, i'm not sure if i did some mistake, as these where some of my earlier modules and now the stripboards are plundered...
jurekprzezdziecki
PostPosted: Tue May 10, 2016 6:43 am    Post subject: Reply with quote  Mark this post and the followings unread
got it:)) just reading!
jurekprzezdziecki
PostPosted: Tue May 10, 2016 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks! i will test it on breadboard first for sure.
jurekprzezdziecki
PostPosted: Wed May 11, 2016 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
just showing a progress with the project Cool
i have changed the schematics a lot for a better legibility and added a PSU sub circuit with supply coupling. so next thing is to put it on the breadboard!
thanks a lot guys! especially Jarnos (LFLab)Smile
 Filesize:  27.66 KB
 Viewed:  305 Time(s)
steved
PostPosted: Wed May 11, 2016 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
i built Bergfors VCA -1 (basically the same VCA )
( http://hem.bredband.net/bersyn/VCA/lm13600%20vca%201.htm )
i don't have any issue with totally muting the signal.
I have made two of these and am able to tune the CV offset / offset to get great results.
I am new to electronics..but i like to experiment - i left the second half of the 13700 disconnected for simplicity and everything sounds great.
I made my PCB using Fritzing - wish i used eagle.
good luck!
jurekprzezdziecki
PostPosted: Wed May 11, 2016 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
good luck!
thanks a lot for the reply. i new t electronics as well, it is my first project actually. i leave a second half of 13600 unconnected as well but if everything will be ok i will make a second channel of VCA.
you said 13700 - so you change the IC? i know they are similar but there is a difference, right? can i change them as well with no consequences?
can i import eagle schematics to Fritzing?
steved
PostPosted: Thu May 12, 2016 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
yes i used 13700 not 13600.
there is a difference, i think it is something with the bias current, but from what i read it doesn't make a difference in most circuits.
I could be wrong.
I use 13700 in VCF and VCA without any issue. 13700 was stocked on mouser but no 13600
i dont think you want to go from Eagle to Fritzing -
Fritzing is real easy to learn and start with, and easy to outgrow.
hope this is helpful - like i said, i am new and don't really know what i am doing ha
LFLab
PostPosted: Thu May 12, 2016 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh yeah, stick with Eagle for sure, it's a learning curve for sure, but totally worth it if you are progressing into more complicated circuits.
I've never used 13600 myself, I think, but they should be interchangeable (13600 is a slightly lower spec, could indeed be the bias current Steve mentioned).
jurekprzezdziecki
PostPosted: Fri May 13, 2016 5:47 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, so i will try to change the op amp just on the breadboard, let's see.
yes, eagle is very complex.. overhelming in some way but it's great indeed.
jurekprzezdziecki
PostPosted: Fri May 13, 2016 5:50 am    Post subject: Reply with quote  Mark this post and the followings unread
last thing - the pots used in the project should be logarithmic, right? not linear?
jurekprzezdziecki
PostPosted: Sun Jun 05, 2016 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
hi guys,
i have build the VCA on breadboard and after some troubles works good.
the only problem is CV modulation. i can't get it work as expected.
the problem is, that a pot (R7) responsible for allows CV modulation only when full down (counterclockwise position). it's not working with any range. every step clockwise gets signal input cut / mute completely.
i don't know how to fix it.
any advices?
i have attached the final schematics - please look
[img][/img]
 Filesize:  19 KB
 Viewed:  173 Time(s)
steved
PostPosted: Mon Jun 06, 2016 4:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
what are you feeding it for CV?
(i dont know if this is the right way to do it, but)
i tune mine in like this:
I send the envelope in to the cv input alone, and turn the cv offset to the point where i can not hear any pop when i hit play a note.
I next plug in my audio and turn it up until it starts to bleed with out CV input.
then i play with the two knobs until it works just right.
For me i run at +-12 v..
ill try and link my version of the schematic.. looks same as yours i think..
hope this helps. you may want to build one of the single transistor VCAs along with this so you can play around more!
