gasboss775
gasboss775
gasboss775
Posted: Sun Apr 09, 2017 10:04 am Post subject:
Some thoughts on processing the output:
The tune is in quite a high register 2-4 KHz, not quite sure what exactly that is in musical terms, but must be a few octaves above middle C. In this respect I think there's potential to bastardize the sickly sweet tune using dividers to generate a different "melody"
I tried it with some ring modulation and I think this may have potential too, particularly if the modulating oscillator was following a pattern of its own rather than just a fixed pitch.
I also tried it with my 4093 NAND Gate Filter with reasonable results ( is more interesting that the square wave with no modulation at all! ) |
gasboss775
Posted: Tue Apr 18, 2017 5:06 am Post subject:
UM3561 |
Tried out the UM3561 this morning:
This ones a sound effect chip rather than a melody generator. It is potentially more interesting in that in addition to the four different sound effects there's an external resistor that sets the internal clock frequency and by varying this with say a vactrol a wider range of sounds can be experienced, sadly I fried one of the control input pins by accidentally connecting it to + 12 V ( the chip works on 3V like the UM66 ) |
Audio files: 705
Posted: Tue Apr 18, 2017 3:29 pm Post subject:
Don't think I have used the UM3561 yet although it does sound familiar so maybe I did order it some time ago but haven't
got to using it yet. I did recently design a synth module with a similar chip though, the CK9561. I am currently working on
putting together the kits for it so once I have those finished I will upload the schematic and more info which might be useful.
Some years ago I used a melody chip intended for doorbells to make the melody mutilator. I wonder if I can find the schematic
to see what kind of chip I used for that.
But anyways, yes! there are a lot of those chips that can be fun to combine with lunettas since the output is usually a digital signal.
edit: checked a video with the UM3561 which sounds very similar if not the same as the CK9561. Using that one would have made
the PCB design a bit easier oh well, maybe I'll make a V2.0 _________________ "My perf, it's full of holes!"
gasboss775
Posted: Tue Apr 18, 2017 4:15 pm Post subject:
I've got another one the SMC0608S, it outputs a series of 6 different alarm/siren type sounds then repeats. It also has an external resistor that sets the internal clock frequency and can be varied over a wide range using this. It also has a stop/reset control pin.
PHOBoS your device looked cool, what was the extension part for? |
gasboss775
Posted: Wed Apr 19, 2017 5:47 am Post subject:
The SMC0608 turns out to be quite interesting even with some fairly simple CMOS circuitry round it. Have tried A 4024 divider, digital ring modulation using an XOR & a square wave oscillator. I've also tried feeding it into my 4093 based filter with good effect, is more effective with binary division via the 4024 prior to going into the 4093 filter.
4093 "Goschillator" Filter |
gasboss775
