 Forum index » Clavia Nord Modular » g2ools utilities
g2ools-1.5 nm2g2 and dx2g2 converters
Page 4 of 14 [328 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, ..., 12, 13, 14 Next
jjpleeza
PostPosted: Tue Jan 16, 2007 6:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm having an impossible time converting these on OSX.
I beg someone to convert these patches for me????
Need them for a gig this weekend and at the moment I'm stuck with nutta!!
Any help will be much appreciated.
Vocoder Patches.zip
My four patches..
 Filename:  Vocoder Patches.zip
 Filesize:  3.67 KB
 Downloaded:  839 Time(s)
modular
G2 patch files: 72
PostPosted: Wed Jan 17, 2007 4:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Wapskallion wrote:
well, hitting enter says
SyntaxError: invalid syntax
Running the script says - Error: Indentation identificatio detected!
as the same to me,what's wrong?
modular
G2 patch files: 72
PostPosted: Wed Jan 17, 2007 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
try typing
./nm2g2
by itself
Also copy and paste the output of that into your next reply
IDLE 1.2
>>> ./nm2g2
this to me
./nm2g2 testseq.pch
Wapskallion
PostPosted: Wed Jan 17, 2007 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm at work now, so will try when I get in tonight - thanks for your help so far
Matt
cappy2112
PostPosted: Wed Jan 17, 2007 6:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
try typing
./nm2g2
by itself
IDLE 1.2
>>> ./nm2g2
this to me
./nm2g2 testseq.pch
I see the problem IDLE is being invoked insead of the python interpreter.
IDLE is an editor/IDE for developing Python scripts. You don't need this to run the script. This is a minor system configuration issue. I don't have a MAC.
Send a PM to 3phase- I think he's an OSX user. Ask him how he got around this problem, then post the reply (if it works for you) here, so others can benefit from it. We need to get qfingers to add some readme files for OSX.
jjpleeza
PostPosted: Wed Jan 17, 2007 7:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Anyone?
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Jan 17, 2007 9:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
jjpleeza wrote:
Anyone?
Here is Talkbox02.pch, the other three wont convert probably because they give errors when loading into the NM classic editor.
Um, these are realy basic patches, take at most a couple of minutes each to convert by hand.
What's up?
BTW I am on XP Pro not mac so cant help with your problems.
Talkbox02.pch2
 Filename:  Talkbox02.pch2
 Filesize:  1.47 KB
 Downloaded:  2103 Time(s)
cappy2112
PostPosted: Wed Jan 17, 2007 10:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Anyone?
You might want to read back through all this thread history.
This toool isn't finished yet, and it's likely some patches will not sound how you expect them to, until the tool is finished
qfingers
PostPosted: Thu Jan 18, 2007 6:45 am    Post subject: Reply with quote  Mark this post and the followings unread
3phase and I have found many bugs and updated many models. We are finishing up now and should have a release soon. I'm hoping to have it done in a couple of days. It took longer because there were tricky some problems to solve and alot of models needed updating.
q
jjpleeza
PostPosted: Thu Jan 18, 2007 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
g2ian wrote:
jjpleeza wrote:
Anyone?
What's up?
Thankyou so much my friend!
Tried doing by hand, but got stuck on a few of the different settings on the new modules..
Couldn't get them to sound the same.
qfingers
PostPosted: Thu Jan 18, 2007 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
g2ian wrote:
jjpleeza wrote:
Anyone?
What's up?
The converter only handles version 3 or greater patches. Was there a problem with the converter? It should have handled this easily.
q
cappy2112
PostPosted: Thu Jan 18, 2007 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Matt
and- what happened when you tried this???
Wapskallion
PostPosted: Thu Jan 18, 2007 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
um... well I went for 'a pint' after work and kind of stayed there all night - sorry I'm letting the team down -
let you know soon as (I'm too hung over to go.. definately making it home tonight) Rolling Eyes
cappy2112
PostPosted: Thu Jan 18, 2007 4:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hehehe. I don't blame you.
I put in almost 20 hours at my job last weekend. I should be having a pint myself.
cappy2112
PostPosted: Thu Jan 18, 2007 5:07 pm    Post subject: For the OSX users having probelms with G2ools Reply with quote  Mark this post and the followings unread
Read 3phase's post about how he got around the problems on OSX
http://electro-music.com/forum/posting.php?mode=quote&p=101376
jjpleeza
PostPosted: Thu Jan 18, 2007 10:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, so this is how I'm "trying" to convert them..
I installed python for OSX.
I open the g2tools folder which is filled with a build sub-folder, a nord sub-folder, lots of test.pch's and 8 .py files.
I place the patch I want to convert in this main folder.
I open the nm2g2.py file and IDLE pops up. There are 2 windows. One has heaps of text in it and the other one is called python shell.
It says,
IDLE 1.2
There I entered ./nm2g2.py then the patch name "talkbox02.pch" and hit enter.
Then I get this response...
SyntaxError: invalid syntax.
What is it i'm doing wrong..?
Can someone guide me through this please?
3phase
G2 patch files: 141
PostPosted: Fri Jan 19, 2007 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
TDLE is just the editor...so it is ok that it says syntax wrong...
But you have phyton running now...
on my machine i just need to doubble click on the nm2g2.py application file that is within the folder..
than a command window pops up
there i type ./nm2g2.py name.pch
and enter and it starts the conversion...
In the beginning i had to use the IDLE editor to change the first line of the nm2g2.py to the location of the phyton libs...
what can be found with the "which phyton" command in the terminal window of os x...
but..i didnt had to do that anymore in the later updates...
So i dont know if the system somehow remembered this or if the applikation got optimized so that is not necessary anymore...
Its a bit digging in the dark when you are not used to this unix type of things..as me... but...
once its running it works like a charm...
the next update that is comming soon also features a function where you can convert whole folders..
So just keep trying... maybe there is an app in your phyton folder that is called phyton launcher..you could try that on nm2g2.py
And..
i placed my G2ools folder direct on the main partition...not in the programs folder...
I dont know if that is necessary but i had permission problems when i had it in the program folder...
Didnt had much time to check it out..and didnt wanted to change anything while i am still on the bug hunt...
Its very complex to get the convertion running on all patches perfect because any little bug or misstranslation can be significant in a specivic patch while 100 others just convert fine and you dont get the idea that something can go wrong...
All this grey signal stuff is really tricky and will probably need some more time to get it sorted out..
but the upcoming update allready can handle many situations that appeard untranslateable for me a while ago...
It started to become better than my hand conversion trys because it adjusts much more details than you can be aware of in a hand conversion.
many modules on the Nm1 work slightly or very differnt than the similar ones on the G2...
I understand now why my handconversions never sounded wright...
The converter is doing a much better job allready than i thought it would be possible...
Hyde
PostPosted: Fri Jan 19, 2007 10:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
i followed your instructions to a 'T'
the first line of all this:
was changed from whatever it was to:
/Library/Frameworks/Python.framework/Versions/Current/bin/python
which is what i got when typing 'which python' in terminal.
BUT
in the python shell - this is what i get:
ugh. this is awesome that we have this and frustrating that it doesn't work. a gui would be so freakin' nice if someone could whip one up in Max or something. otherwise - we (Mac OSX users) need a better tutuorial...
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri Jan 19, 2007 11:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
could you try not putting the ./ in there?
I am not a unix user but isn't ./ just a shorthand for the current directory, which is the default anyway?
Hyde
PostPosted: Fri Jan 19, 2007 11:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
i did try that before posting because i thought the same thing. but it still didn't work.
3phase
G2 patch files: 141
PostPosted: Sat Jan 20, 2007 12:01 am    Post subject: Reply with quote  Mark this post and the followings unread
again..this thing is not run from the editor.. (IDLE)
i went thru all this trouble aswell but eventually i got it working...
maybe i ve my routines to finding my way around in computers but that is mainly based on keep trying than any unix knowledge...
It got working for me after i had g2ools removed from the program folder... in the main directory. And that dont necessaryli means that this is necessary..that was just the chronologic order
than i started IDLE changed the header...
nothing happen... same as the state you are in... I supposed that this thing wasnt ment to work from the editor...
I used the Phyton Launcher again...or tried to assign the phyton launcher to the nm2g2.py file...with the apple/I infobox...
afterwards all .py files got the phyton logo...
i double clicked on nm2g2.py
a command window popped up..
i was abel to convert patches with the
./nm2g2.py command...
There is nothing more i can tell about it...
but maybe the assigning of phyton launcher did it???
which phyton you have installed? I got Mac Phyton 2.4
Hyde
PostPosted: Sat Jan 20, 2007 12:43 am    Post subject: Reply with quote  Mark this post and the followings unread
ok - i am using MacPython 2.5.
i did what you said and did the 'Get Info' and assigned the nm2g2.py file to be opened with Python Launcher instead of IDLE.
but now when i double click the 'nm2g2.py' file it opens up two Terminal windows - one of which says this (and i can't type anything into it:
Last login: Sat Jan 20 01:40:06 on ttyp1
Welcome to Darwin!
Hyde:~ Hyde$ cd '/Users/Hyde/Desktop/g2ools-1.0/' && '/usr/local/bin/pythonw' '/Users/Hyde/Desktop/g2ools-1.0/nm2g2.py' && echo Exit status: $? && exit 1
Exit status: 0
logout
[Process completed]
and the other one is just an empty Terminal window.
cappy2112
PostPosted: Sat Jan 20, 2007 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Welcome to Darwin!
Exit status: 0
logout
[Process completed]
Instead of double clicking- why not just open a command window in the directory where g2ools are, and just run it from there?
cappy2112
PostPosted: Sat Jan 20, 2007 1:02 am    Post subject: Reply with quote  Mark this post and the followings unread
It says,
IDLE 1.2
type which python
and past the results into the reply to this message
another thing you can try is
once you find out where the python interpreter is
invoke it using the full path to it as in
/pathname/subdir1/python ./nm2g2 mypatch.pch
There is apparently some issue on OSX where the IDE is being invoked instead of the python interpreter. This should be easy to fix- it's a system configuration issue.
Do you know how to change program associations?
We need to change the association with IDLE, and replace it with the python interpreter. Try posting a message in a mac users forum- asko how to change program associations.
cappy2112
PostPosted: Sat Jan 20, 2007 1:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Welcome to Darwin!
Exit status: 0
logout
[Process completed]
Would you try this?
Open a cmd prompt window- so you can enter cmds, but cd into the directory where g2ools is installed
then try invoking the python interpreter like this (but subsitute a real patchname)
/usr/local/bin/pythonw ./nm2g2.py patchname.pch
or try this
/usr/local/bin/python ./nm2g2.py patchname.pch
(without the 'w' on the end of python)
if that doesn't work type
ls -asl /usr/local/bin/pythonw
and paste the output inot your reply
is there a file called python as well as pythonw in /usr/local/bin ?
On windows, pythonw will launch a gui app, without the console window.
On osx there may be slightly different implications
