 Forum index » electro-music.com
Guest posts
Page 1 of 1 [8 Posts]
PostPosted: Fri Mar 09, 2007 3:04 pm    Post subject: Guest posts Reply with quote  Mark this post and the followings unread
Is it possible to remove the topics started by Guest and similar users? Most of all they are scary - I'm having nightmares of this forum being clogged up with trash. Sad
/Stefan
PostPosted: Fri Mar 09, 2007 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ahh.. an ownerless spermpost? Yeah, we have a few stray ones still left in here. Shocked
Flickr
PostPosted: Fri Mar 09, 2007 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Those posts should indeed not be present.
Sometimes when a spammer post something and the spammer is deleted before the post, the post will turn into a ghost post that can't be removed anymre through the forum interface.
Are there many such posts present currently ?
I don't see 'm often anymore I must say.
PostPosted: Fri Mar 09, 2007 3:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Forum index » Instruments and Equipment » General Discussion (quite a few here)
Forum index » Instruments and Equipment » Windows as a music workstation
Not complaining really by the way Smile , I was just getting nervous that this might be growing into a serious problem.
/Stefan
PostPosted: Fri Mar 09, 2007 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
It requires some attention, but it's not as bad currently as a while ago.
PostPosted: Fri Mar 09, 2007 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Knock on wood.
Audio files: 227
PostPosted: Sat Mar 10, 2007 2:56 pm    Post subject: Re: Guest posts Reply with quote  Mark this post and the followings unread
/Stefan
Thanks, Stafan, for the heads up. I think an administrative program I wrote has a bug. It deletes the posts, but leaves the topics. Gotta get back to work. Crying or Very sad
Audio files: 227
PostPosted: Sat Mar 10, 2007 9:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have modified the admin program and manually deleted all of the guest post. If you find any others, please let me know. The forum has gotten so large, no body can keep up with everything, so we need all of the members to let us know when they see stuff that needs attention.
thanks
