Mohoyoho
Joined: Jan 31, 2003 Posts: 18247 Location: Durham, NC
Audio files: 225
Posted: Sun Apr 11, 2004 1:15 pm Post subject:
I don't think it's a question of getting the Evolver or the G2. I think, after you get the G2, what of your existing gear can you get rid of?
Seriously, the G2 is really fabulous, but it is for patchers. If you aren't into rolling your own sounds, you won't like the G2 a bit. If you like sound design, then what else is there that compares to the G2? I think a Kyma, but way more money, and a much steeper learning curve.
If his image doesn't lite your fire,
and this one does,
then get an Evolver. Last edited by mosc on Sun Apr 11, 2004 2:03 pm; edited 1 time in total |
Mohoyoho
Audio files: 225
Posted: Sun Apr 11, 2004 2:00 pm Post subject:
My screen shot of the G2 editor is of a full hi res screen shrunk quite a bit. Here is a screen scrape of just a protion of the screen, but at actual size so you can get an idea how it looks in reality.
As you can see, there is a lot of detail, but it's readable. You can use a lower res screen than I and it will look bigger, but you won't be able to get as much on the screen.
Quote: | I like to roll my own. But I also like to take others' patches and modify them to my taste. |
Sharing patches is one of the great things about the NM products. If you are working on a patch, I'm sure there will be people to help you work the bugs out, right here on this forum. With the NM products, you are never alone. |
jimh54
Posted: Sun Apr 11, 2004 6:36 pm Post subject:
Apples and Oranges |
that is correct, I have a G2, G1, and an Evolver. the kinds of sounds the evolver can generate would be very difficult to create on a G2, I think. I have never heard anything else like the evolver and I have had a lot of synths since 1977 to the present.
That is not to say that either is better. just different. I have the first evolver model ($500), so it is not too big of an investment. I would like to get the poly when it comes out but you still need to first model for the controls. unless you intend to strictly edit using a computer.
I'd get both a g2 and an evolver. Trouble is, you do that and you end up getting three not two synths. If you must get just one, the g2 has far more modules to control. but the evolver just has that analog sound that can't be duplicated with a digital synth.
Good Luck in your choice |
Mohoyoho
Audio files: 225
Posted: Mon Apr 12, 2004 5:56 am Post subject:
Jimh54, welcome to our site.
Thanks for joining in this discussion. Since you have both synths in question here, I defer to your opinion. I wonder if you might post as an attachment an mp3 file of an example of the type(s) of sounds(s) the Evolver makes that would be difficult for the G2. Just curious. |
seraph
Editor
Audio files: 33
Posted: Mon Apr 12, 2004 6:15 am Post subject:
mosc wrote: | the G2 is really fabulous, but it is for patchers. If you aren't into rolling your own sounds, you won't like the G2 a bit. |
I think that says it all. I am more interested in composing than sound designing, besides that I have such a huge collection of every possible sound that I think I will never be able to use them all anyway so why bother making new ones except for fine tuning existing sounds, effecting them etc.  _________________ homepage - blog - forum - youtube
Quote: | Don't die with your music still in you - Wayne Dyer |
Mohoyoho
jakeez
Audio files: 225
Posted: Fri Apr 23, 2004 7:41 am Post subject:
Jakeez, welcome to electro-music.com, and to the G2.
I listened to your track. I bit heavy on the echo and reverb to my taste, but that's just my bias. I'm also suffering from an ear infection right now, so don't take my feedback as negative. Keep on making music. |
Joined: Apr 03, 2004 Posts: 24446 Location: The Netherlands, Enschede
Audio files: 297
Posted: Fri Apr 23, 2004 1:06 pm Post subject:
Mohoyoho wrote: | What interests me in the Evolver is the possibility of lengthy "evolving" pads. I'm assuming it can do that. Is that one of the Evolver's strengths Jimh54? |
When you mean 'self playing patch' (or noodle) when you say 'evolving''pad' than the G2 would be very suitable ... using the inter-slot communication possibilities you would be able to create one huge self playing patch using all eight DSPs (on an expanded system).
Jan. |
egw
Joined: Feb 01, 2003 Posts: 1569 Location: Asheville NC
G2 patch files: 8
Posted: Tue Apr 27, 2004 8:29 am Post subject:
Jakeez, Ardmore is not far away - we should get together for a G2 jam some time - there are at least 4 of us in the area now! |
