today> Cancelled due to equipment failure - Sorry Chez Mosc
Post Your KLEE Panels Designs Here
Page 3 of 16 [399 Posts]
Goto page: Previous 1, 2, 3, 4, 5, ..., 14, 15, 16 Next
mono-poly
PostPosted: Tue Nov 27, 2007 9:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Norman Phay wrote:
mono-poly wrote:
Norman Phay wrote:
mono-poly wrote:
My Wiard Klee slider version.
Need to do another 2 in different formats.
WOW that looks awesome, Denis. You wouldn't be into making an extra one up, by any chance, would you?
Norman if Grant agrees that you can have a panel.
Then i would be happy to share the panel design with you.
I can't just share stuff with his graphics without his permision.
But if he agrees you could have a panel like this to.
Should I email Grant about this, then? Loads of thanks, man.
Yeah email him or maybe a phonecall?
loopcycle
PostPosted: Tue Nov 27, 2007 12:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Photon wrote:
Heres the preliminary design for the panels for my Klee desktop unit. Its split into two panels (the console is wedge shaped). The sliders will be on a 15˚ sloped face. The other will be horizontal. all jacks are positioned in the back to help with wire management. I was heavily influenced by the work of the industrial designers over at DEC in the mid-sixties. Hopefully that shows. I'm going to have these reverse printed onto the back of 5 mil velvet lexan, so they'll be quite durable.
thanks for posting that layout. i like the vertical flow of the subgroupings in each logical control grouping and the space allowed between them...this was something i was thinking about/working out in my own design (avoiding a design that pulls my visual attention in multiple directions or is just too busy).
loopcycle
PostPosted: Tue Nov 27, 2007 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Uncle Krunkus wrote:
Here's the sub panel, finished and ready for the sliders.
another idea for the subpanel--what if: instead of measuring/drilling/countersinking each slider mounting hole on a subpanel, two rectangular slots were cut out, allowing variable mounting locations of each slider (for a little more 'wiggle' room)? there might be more room for error between the front panel and the subpanel, and it might be way cheaper to make as an FPE panel. just thinking out loud here. Idea
PostPosted: Tue Nov 27, 2007 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think the only issue with that, (which I kinda mulled over a bit at the time) is how close the subpanel is to the main panel. If, like me, your spacings mean that you want it flush, a slot won't work, as you'd have to put angled edges on it to accomodate countersunk screws, and then they would "spread" the slot.
If, however, you ditch the spacers on the sliders, use short mushroom head screws to mount the sliders in the slots, and then set it back from the main panel by putting washers on the switches (between panels) then this would make clearance for the mushroom heads. I suppose you wouldn't really need washers, It would all sit flat anyway because of the size of it. Just be sure the switches thread is long enough for both panels and the depth of the screw heads.
I'm kinda impressed that I came up with the same idea as was used on the MS20. Very Happy Cool
factus10
PostPosted: Tue Nov 27, 2007 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm still contemplating the slider vs rotary pot but I know if I do sliders, I'm just going to cut out a big ol' hole instead of individual slots. I figure I'll slap some of that craft foam or felt in front of the sliders to catch dust.
PostPosted: Tue Nov 27, 2007 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
factus10 wrote:
fonik,
was your panel done by shaeffer? would you mind uploading the fpe file if so?
thanks!
david
yes, a schaeffer panel. i gave it to mono-poly so i could contribute it to the thread also, i guess. i will leave off the graphics, though - just the holes. i actually don't want to see a copy of my very green klee Wink
will upload it tomorrow.
mono-poly
PostPosted: Tue Nov 27, 2007 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool Smile
Thanx for letting me use yours as a basic idea.
But i changed a lot, but i liked the main idea!
factus10
PostPosted: Tue Nov 27, 2007 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks! your panel hits some of the main points for me (like a din jack for midi) and I'm not super adept at FPE just yet so a reference to play with would be awesome.
goodrevdoc
PostPosted: Tue Nov 27, 2007 6:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Ryk, those same C&K switches are going cheap over at electronic surplus: C&K Switches
-justin
Scott Stites
Audio files: 96
PostPosted: Tue Nov 27, 2007 6:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Holy crap! If those are 7211's (number seems to indicate it), that's a helluva good deal. Love those 7211's.
Is anyone else having any problems viewing page 2 of this thread, or is it just my crap computer?
Cheerio,
Scott
My Site
Danno Gee Ray
PostPosted: Tue Nov 27, 2007 6:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just looked at page 2 ok. Must be at your end.
Scott Stites
Audio files: 96
PostPosted: Tue Nov 27, 2007 6:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Crap!
Laughing
It's been one of those days.......
My Site
loopcycle
PostPosted: Tue Nov 27, 2007 10:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
page 2 is a bit heavy on the attachments. Very Happy
PostPosted: Wed Nov 28, 2007 12:00 am    Post subject: Reply with quote  Mark this post and the followings unread
here's a blank panel for playing around...
klee2_blank.zip
 Filename:  klee2_blank.zip
 Filesize:  2.55 KB
 Downloaded:  1077 Time(s)
Luka
PostPosted: Wed Nov 28, 2007 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
ok here is my second round try on 5x9U format
took a few peoples suggestions in such as giving more space on the left for left hand tweakage and flippage. also tightened up my graphics a bit more, starting to get the hang of front panel designer i think.
love some more critique
Klee-problemchild-B.pdf
2nd round klee attempt
 Filename:  Klee-problemchild-B.pdf
 Filesize:  28.32 KB
 Downloaded:  1152 Time(s)
problemchild
melbourne australia
PostPosted: Wed Nov 28, 2007 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
that's what i call compact. i like it.
mono-poly
PostPosted: Wed Nov 28, 2007 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am working on this one.
It's almost done but i need to think about it.
345 euro schaeffer panel!
Shocked
 Filesize:  146.45 KB
 Viewed:  980 Time(s)
PostPosted: Wed Nov 28, 2007 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
did you adapt all our price reducing techniques? (no color fill, one text object with multiple paragraphs, hpgl for scales)
mono-poly
PostPosted: Wed Nov 28, 2007 3:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nope i should check it out.
Because this price makes no sense.
And i am not 100% happy with the layout yet.
Pehr
PostPosted: Thu Nov 29, 2007 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's my Klee! Twisted Evil
Thanks to Etaoin for the panel layout. I modified it a little to suit my system.
There are more pictures in this thread on a swedish electronics forum.
Oh... and the wiring is not finished yet Rolling Eyes Embarassed
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
PostPosted: Thu Nov 29, 2007 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very Nice Work. Very Happy
Alienation
PostPosted: Thu Nov 29, 2007 7:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice indeed...... Very Happy
23isgood
PostPosted: Fri Nov 30, 2007 1:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, very nice. I really like the table top box approach. Cool stuff fur sure!
Check out my music
Pehr
PostPosted: Fri Nov 30, 2007 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! Very Happy
I wanted a tabletop-box for the Klee because I thought it'd be good to have the controls close to me and no patch cables hanging over it.
It looks really good in front of my modular! Very Happy
Now to the wiring... Rolling Eyes
EDIT: note the logo in the back Cool :
YouTube channel
flickr photostream
loopcycle
PostPosted: Sat Dec 01, 2007 3:36 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, so ive been mulling the panel layout day and night. it feels like an obsession--im dreaming about panel and i wake up thinking about soldering Rolling Eyes anyway, i decided that i would at least proto one or two designs in easily-obtainable/cheap material before i get the nerve (and cash) up to do a proper FPE panel. so, without boring you with the mental journey ive taken, i found my enclosure: a wooden box. it has a working area of about 12" high x 15" wide for all panel components, and there is room inside for its own PSU and the circuit boards.
now the enclosure is helping to direct my thoughts about laying my components out...and an idea struck me--im thinking of laying out my 1-16 steps out something like:
Code:
1 -  2 -  3 -  4 -  5 -  6 - 7  - 8
16 - 15- 14 - 13 - 12 - 11 - 10 - 9
(two rows of 8 each work well for the enclosure shape)
the leds would be in the center.
then the rotary pots (no sliders).
then the bit enable switches.
finally, the gate bus switches.
its basically a rectangular radial shape.
ill try to provide a layout soon, but this is probably a good description.
i would like to hear any thoughts about shortcomings or disadvantages of this design (BEFORE i start drilling Laughing )--thanks!
