Post Your KLEE Panels Designs Here
Page 5 of 16 [399 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, ..., 14, 15, 16 Next
PostPosted: Sat Jan 12, 2008 5:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Fonik!
It's nice to know people appreciate my obsessivness. Very Happy
factus10
PostPosted: Sun Jan 13, 2008 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep, I remember Krunkus' panel. Quite ingenious and nice. I'm not that concerned with the screws; I plan to touch them up with black lacquer so they'll blend a little bit better.
andrewF
PostPosted: Wed Jan 16, 2008 6:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I started my Klee mid last year....June or so Sad Life got in the way...or something.
didn't buy the EM boards as i already had started a vero version.
Dug it out this week, must be time to finish it.
I took a few shortcuts -
the clock and load momentary switches are wired to the clock and load jack switches. As i understand it, it means i cannot use the momentaries when a clock or load signal is patched in.
The clock jack runs via the normally closed(H) hold switch.
left out the gate/trigger circuitry, just have 16 buffer/LEDs/gates running from the 4034s, similar to those in Ken Stone" Gated Comparator (that is the smaller board on the left).
also the level select is simply a 9v regulator and diodes wired in series on the rotary switch, or external input.
the panel is the cover off a dead PC, switches, knobs, stick-on labels, pots all came out of the dumpster behind the Physics dept. at uni.
LEDs and jacks are new though.... Wink
I played around with many different panel designs, gotta say thanks to EdisonRex, the panel you posted in this thread was inspiring.
Of course Thanks to Scott, Uncle Kr. and EM for putting out this design.
 Filesize:  44.54 KB
 Viewed:  16137 Time(s)
 Filesize:  53.65 KB
 Filesize:  47.03 KB
 Viewed:  394 Time(s)
PostPosted: Wed Jan 16, 2008 7:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow,
Very nice work Andrew! Very Happy
andrewF
PostPosted: Thu Jan 17, 2008 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
cheers
its a bit minimalist.....i did have some plans to splash paint all over it but the paint tasted funny
Anyway, hope the cct works, no doubt there will be a few things i have forgotten
EdisonRex
Audio files: 172
PostPosted: Thu Jan 17, 2008 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shit. I looked at the picture before I read your text, and I said to myself "damn that looks familiar".... !
That panel looks great, Andrew. It's actually closer to what I was thinking when I started my panel design.
I've had a real crap December and January, financials have been pretty much shit, most of my pay comes once a year and it didn't come yet. So my panel (and the time to work on it) has been waiting because of the work.
This inspires me though. I have the boards completed. Just I'm kinda stressed about money with 3/4 of my income held for ransom right now.
Thanks for posting that. It's really cheered me up. I'd like to see the thing work too.
Garret: It's so retro.
PostPosted: Thu Jan 17, 2008 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
andrewF wrote:
cheers
I must admit, it doean't look alot like the stripboard I designed.
That's kind of a relief actually, as the ones I did are untested! Laughing
So if it doesn't work, it aint my fault! Laughing Wink
andrewF
PostPosted: Thu Jan 17, 2008 7:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good! things have been a bit rough here too, so i did the panel to relax a bit. Drilling holes is a great stress release....not sure about wiring though.
andrewF
PostPosted: Thu Jan 17, 2008 7:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think someone here has built your stripboard version, there was a post about it last August or so.
mine is just off the schematic, not much thought about it really. just work out where the ICs go, then start on page1/input circuitry and work my way thru to the outputs. i originally used the schematic in your Uncle K. Zip file, and added the extras, like invert switch, from the latest pdf version.
PostPosted: Fri Jan 18, 2008 12:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool,
It would be good to hear if the stripboard actually worked.
andrewF
PostPosted: Mon Jan 21, 2008 8:00 pm    Post subject:   Reply with quote  Mark this post and the followings unread
yay worked 1st time, mostly. i think?, its a strange 'un! better read the user's manual.
guess i should mount the boards somewhere better than a notebook.
obligatory spaghetti picture -
 Filesize:  57.91 KB
 Viewed:  15981 Time(s)
PostPosted: Mon Jan 21, 2008 8:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like it very much! Hi five?!
Alienation
PostPosted: Mon Jan 21, 2008 8:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice job.
Did you buffer the blue LED's? They are a nice touch.
Congrats! Cool
andrewF
PostPosted: Mon Jan 21, 2008 9:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes, I didn't build this as per the schematic, its a bastard Klee.
The 16 jacks across the top of the panel are stage outs, connected via the blue LEDs. If you check out the CGS Gated comparator you can see how i did it.
If you are building a regular EM Klee PCB, I think you can happily use blue LEDs without buffering.
I didn't build the gate/trigger section of a std. Klee, mainly cos the veroboard was chockablock with the rest of the cct. Maybe i will build it in future, easy enough to add it on.
cheers
slo
PostPosted: Sun Jan 27, 2008 9:01 am    Post subject:
Subject description: My Klee Panel
Here's my Klee front panel finally done. I had a lot of trouble with the Lazertran process I am using and had to clean it off twice and repaint, Lazertran is finicky and while I've got he knack for smaller projects, this is the first large one I've done and it was problematic. The final panel has blemishes here and there, but I could'nt wait any longer. I went with the 60mm sliders and I think you can see bits and pieces of every other Klee front panel in the design, thanks guys, you know who you are.
George
 Filesize:  54.6 KB
 Viewed:  570 Time(s)
 Filesize:  57.52 KB
 Viewed:  394 Time(s)
Alienation
PostPosted: Sun Jan 27, 2008 9:21 am    Post subject: Reply with quote  Mark this post and the followings unread
That's a very nice job on the panel. Cool
The lazertran is a nice way of labelling, I have been considering similar labelling for mine.
Did you do all the metal work?
Again, Nice job.
slo
PostPosted: Sun Jan 27, 2008 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, it was a lot of work. I did all the metal work, I have a drill press, and for the slots I used a 4.5 inch grinder, with a 1/16 disc, mounted in a stand which I then plunged into the secured metal, a bit of filling on the ends to square up and the slots where done.
Lazertran can be a pain. I print it reverse, put it toner down on the metal, then bake it in the oven. It has mixed results, and while the photo does not show it, there are large areas of blemishes on my panel where the Lazertran did not change properly with the heat.
George
PostPosted: Sun Jan 27, 2008 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
i once played a little with lazertran and this oven mehod and experienced the same problems.
anyway, wow! super nice and professional looking panel...
PostPosted: Sun Jan 27, 2008 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's a very nice job you've done there George. Very Happy
I've never oven baked the lazertran, just polyurethane and gum turpentine onto wood, but I have also had problems with large areas. I'm confident about doing smaller sections, which I plan on sticking with now.
I did the Klee with two sheets, my ASM-2 took about six sheets and was my first try. I realise now that I was quite lucky that it turned out as good as it did.
Your panel looks really professional. Nice layout and graphics.
andrewF
PostPosted: Sun Jan 27, 2008 5:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great panel!! - I was wondering about cutting slots for sliders with a grinder, so thanks for explaining the method, from the pic they look very straight.
(there is a box of 250 slider pots in my cupboard).
Lazertran - never worked for me, was like trying to unravel a spider web without breaking it Mad
Now to do the wiring and do some Klee!
slo
PostPosted: Sun Jan 27, 2008 7:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
For sure! the rest should be easier than the panel.
Thanks for the kind words people, I can upload the Front Designer file for the panel if anyone wants it.
George
PostPosted: Fri Feb 01, 2008 5:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
George, just dropped in to take a peek at the panels ... really nice job. I love it. I really like the slider based panels that have been done Cool
I should really post my Klee panel here also .....
Bill
 Filesize:  295.6 KB
 Viewed:  566 Time(s)
 Filesize:  523.06 KB
 Viewed:  457 Time(s)
factus10
PostPosted: Sat Feb 02, 2008 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow... and what's all that other cool stuff in the racks? Wink
Alienation
PostPosted: Sat Feb 02, 2008 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, lots O' colors.
Tell us about your stuff, I see Blacet and Wiard represented. What's above the Klee and below it.
PM if you need to to keep the thread straight. Wink
slo
PostPosted: Sat Feb 02, 2008 7:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I really liked your panel Bill and it was an inspriation for me, I copied your little motif for the glide pots. Nice rack o' stuff too! I see some PAIA stuff there, they are the ones that send me down the rabbit hole....Smile
George
