Ambiophonic encoder - Reaktor
Page 1 of 1 [8 Posts]
bachus
PostPosted: Tue Apr 01, 2008 1:20 pm    Post subject: Ambiophonic encoder - Reaktor Reply with quote  Mark this post and the followings unread
This version now conforms to the corrected diagram.
AmbiophonicICC.ens
 Filename:  AmbiophonicICC.ens
 Filesize:  80.65 KB
 Downloaded:  1127 Time(s)
Audio files: 226
PostPosted: Wed Apr 02, 2008 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Errrrr - do you have to have a copy of Reaktor to use this?
bachus
PostPosted: Wed Apr 02, 2008 1:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Who me? But of course! Reactor 5; How else would I have created it? Shocked
And yes, obviously that's what I should use to do the phase/time correct panner. I've just always used it stand-alone and my brain is ossifying. Crying or Very sad
Edit:
By which I mean it never occured to me Shocked
bachus
PostPosted: Thu Apr 03, 2008 7:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
I should note that I used core cells for the delays. It may not be possible to create the very shore delays needed in earlier versions of Reaktor because they do not have core cells.
Also if you set the ICC attn (the Interaural Crosstalk Cancellation factor) control too high (~less then -.85) there is some ringing on transients.
bachus
PostPosted: Wed Apr 16, 2008 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Just a note to say that I forgot to upload the corrected version until today.
Audio files: 226
PostPosted: Wed Apr 16, 2008 7:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can you export a Reaktor synth as a VST?
bachus
PostPosted: Wed Apr 16, 2008 7:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sigh -- no. and they don't even market Reaktor Session any more, the (*^%*&(#!~s
You can load it as a VST but you still have to have Reaktor.
Audio files: 226
PostPosted: Wed Apr 16, 2008 7:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Too bad... sigh
MAX/MSP let you write stuff as VSTs. It's a good thing.
Anyway, with your program you can play CDs and that's the most important thing.
I want a RACE VST!!! Crying or Very sad
