dorremifasol
Joined: Sep 28, 2006 Posts: 823 Location: Barcelona, Spain
G2 patch files: 49
Posted: Tue Apr 29, 2008 12:07 pm Post subject:
AliasSeq |
You know when you design a simple patch, and then you start adding modules and it ends being a totally different thing? Of course you do!
It's nothing special since I'm far from being a G2 guru, but I'm pretty proud of this one, so let me share this patch evolution with you.
The filter (I love this one) is cannibalized from a filter test of other user, which I don't remember now, that was HIS great work.
By the way, I kept it using only one DSP so it can be played in the G2 demo. Enjoy!
Description: |
the patch that started it all, provoking low quality oscillators to add imperfection to the sound before the filter |
 Download (listen) |
Filename: |
AliasLead.pch2 |
Filesize: |
2.15 KB |
Downloaded: |
1948 Time(s) |
Description: |
the same with a "living" oscillator |
 Download (listen) |
Filename: |
AliasLead2.pch2 |
Filesize: |
2.19 KB |
Downloaded: |
2076 Time(s) |
Description: |
and now with a little sequence |
 Download (listen) |
Filename: |
AliasLead4.pch2 |
Filesize: |
2.95 KB |
Downloaded: |
1958 Time(s) |
Description: |
using the rest of DSP to bring drums and other details |
 Download (listen) |
Filename: |
AliasSeq1.pch2 |
Filesize: |
5.46 KB |
Downloaded: |
1904 Time(s) |
Description: |
 Download (listen) |
Filename: |
AliasSeq2b2.pch2 |
Filesize: |
5.9 KB |
Downloaded: |
2030 Time(s) |
_________________ Cheers,
Albert |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Tue Apr 29, 2008 8:53 pm Post subject:
Thanks for posting. Sounds very analog  |
dorremifasol
G2 patch files: 49
Posted: Tue Apr 29, 2008 11:23 pm Post subject:
Thank you G2ian! I'm glad you mention the analog sound. I'm a bit obsessed abut obtaining the most analog sound out of the G2. Perhaps because I can't spend money on buying a real analog synth.
By the way, have you noticed that the main waveform I use for the sequence (TriSaw) has only positive cycle? Seems a bug to me. In order to achieve the maximum dynamic range I must eliminate the DC offset by hand.
The DualSaw in the Osc B model also has double the amplitude than the other waveforms. (?) _________________ Cheers,
Albert |
iPassenger
Joined: Jan 27, 2007 Posts: 1068 Location: Sheffield, UK
G2 patch files: 78
dorremifasol
G2 patch files: 49
Posted: Thu May 15, 2008 12:08 pm Post subject:
That's quite a compliment, thank you very much!  _________________ Cheers,
Albert |
varice
Joined: Dec 29, 2004 Posts: 961 Location: Northeastern shore of Toledo Bend
Audio files: 29
G2 patch files: 54
Posted: Fri May 16, 2008 8:41 am Post subject:
I like the final result of the evolution of these patches!
dorremifasol wrote: | By the way, have you noticed that the main waveform I use for the sequence (TriSaw) has only positive cycle? Seems a bug to me. In order to achieve the maximum dynamic range I must eliminate the DC offset by hand.  |
Yes, this is a bug in the Demo Software. It was mentioned here:
http://electro-music.com/forum/topic-13420.html _________________ varice |
Chrono
Audio files: 37
G2 patch files: 38
Posted: Mon Oct 06, 2008 7:19 am Post subject:
ye sounds like a arcade game great |
