 Forum index » Clavia Nord Modular » G2 Patches - Completed » Classic
Save a Prayer
Page 1 of 1 [10 Posts]
modular
G2 patch files: 72
PostPosted: Mon Aug 23, 2004 4:51 pm    Post subject: Save a Prayer Reply with quote  Mark this post and the followings unread
I've arranged another g2ian's patch (filttest1.pch) where I've added FX and build variations too.
Well, go to play var. 3 with the following notes: D-E-F-A-C-A-C-A,doesn't remember any familiar song?
You can bypass/active Delay with Knobs (Page E 3rd Column)
Save a Prayer.pch2
The famous arpeggios of the same titled song
 Filename:  Save a Prayer.pch2
 Filesize:  2.29 KB
 Downloaded:  2468 Time(s)
AntonyPath25
PostPosted: Tue Sep 12, 2006 5:13 pm    Post subject:  GOOD Reply with quote  Mark this post and the followings unread
It's GoooooooooooooD !!!! Cool
modular
G2 patch files: 72
PostPosted: Wed Sep 13, 2006 12:23 pm    Post subject: Re: GOOD Reply with quote  Mark this post and the followings unread
many thanks! You welcome. welcome
grantransom
G2 patch files: 13
PostPosted: Fri Sep 15, 2006 6:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool patch,
- I did a "save a prayer" patch for the NM1 with a direct emulation of the MKS50 architecture including the non-standard osc's and roland type chorus - using my MKS for reference.
I will port all of the old sounds eventually. The MKS was/is a great unit.
A tricky sound to really nail is the flute/synth lead of this track.
Grant.
Grant
cappy2112
PostPosted: Mon Feb 05, 2007 9:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
grantransom wrote:
Cool patch,
Grant.
Grant- you do know about the NM-G2 patch converter don't you?
It might be a good experiment to hear how that patch sounds after conversion.
grantransom
G2 patch files: 13
PostPosted: Tue Feb 06, 2007 3:17 am    Post subject: Converter Reply with quote  Mark this post and the followings unread
I just found out about this...
I'm away at the moment, but I'm itching to try this on a load of patches.
Grant
cappy2112
PostPosted: Tue Feb 06, 2007 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
grantransom wrote:
Cool patch,
Grant.
I'd like to hear the NM and/or G2 versions of this (Or any other Duran Duran songs you did.
grantransom
G2 patch files: 13
PostPosted: Wed May 16, 2007 5:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Just started porting some sounds to G2...
Have posted a few in the respective Forums.
Grant
cappy2112
PostPosted: Wed May 16, 2007 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
grantransom wrote:
Cool patch,
Grant.
Is that not a Jupiter 8- or Jupiter 4?
grantransom
G2 patch files: 13
PostPosted: Wed May 16, 2007 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Probably,
Maybe it's the production, but I'm sure I can hear some non-standard stuff happening, over the vanilla patch.
Grant
