AMORE - an interesting concept
Page 1 of 1 [14 Posts]
magnus
PostPosted: Sat Jun 07, 2008 4:21 am    Post subject: AMORE - an interesting concept
Subject description: AMORE is a synth module concept
Jörgen Bergfors (of the Bergfotron fame) has created a new module concept which seems very well thought thru. Please check it out.
http://hem.bredband.net/bersyn/amore.htm
In short, it is a form of standardised format (three sizes) and module pinning. While this is a limitation for a few modules, it should allow a bulk of modules to use the same panels and same test-platform.
You could even make a standard front panel and just replace the printing plate as you move the modules around in your modular.
BananaPlug
PostPosted: Sat Jun 07, 2008 5:16 am    Post subject: Reply with quote  Mark this post and the followings unread
So any module can have no more than two inputs, two outputs and six controllable parameters. My research has proved this to be enough.
I suggest further research.
PostPosted: Sat Jun 07, 2008 6:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I think it looks like a really good idea.
I do wonder though why there can't be any switch/digital connections. I also have a problem with the connector itself, as a quick check showed that those 2*20way right angle headers are not easy to get. Maybe IDC connectors would be better, or even D connectors, which are plentiful and cheap.
magnus
PostPosted: Sat Jun 07, 2008 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
The inputs are actually inputs to summation points. Thus, the panel can have
more signal inputs but they end up in either of the two signal input summations.
I too initially thought it was a little tight. There is for sure allways modules which does not fit the limit. I think you have too look at it this way, if 90% of the modules in a modular fits the limits, there is alot of gain in it.
Audio files: 297
PostPosted: Sat Jun 07, 2008 6:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked we still use 'm by the bucket full at work ... that is the 100 mil stuff ... male / female / right angle / straight / single row / double row / everything ... maybe look for the snap-off variety instead of strictly 2*20 ?
PostPosted: Sat Jun 07, 2008 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm just saying my "bread & butter" supplier (Jaycar) doesn't have them. Which is not all that surprising, the list of stuff I can't get at Jaycar is as long as my arm. I just thought that if you're designing a new standard you should try to use parts which can be found at the fruit shop. Know what I mean?
PS, Now you wouldn't dare tell me that you work at a fruit shop would you Jan? Laughing
Audio files: 297
PostPosted: Sat Jun 07, 2008 5:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
As long as you don't call me a fruit cake Laughing
I'm surprised, this is bread and butter connectivity still I'd think, and at least they should have the snap off stuff so you cam make your own length.
magnus
PostPosted: Sun Jun 08, 2008 2:25 am    Post subject: Reply with quote  Mark this post and the followings unread
This is strange. I consider it an easy connector to get. I think it says more about your supplier than a generic supplier. But then again, we live at opposite parts of this world.
otherunicorn
PostPosted: Mon Aug 11, 2008 4:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Perhaps you should try "upgrading" to www.rockby.com.au
Jaycar are well on the way to becoming a "Dick Smith", which is now nothing more than a "Tandy".
http://www.cgs.synth.net/
PostPosted: Mon Aug 11, 2008 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks heaps for the link otherunicorn! They look really good. Very Happy
françois
PostPosted: Wed Oct 22, 2008 6:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh yes! What an interesting idea!
I posted some time ago (on this forum IIRC) some similar thing, entitled "Universal Control Panel", but it was only a design idea. You managed to make it an actual design. Although I do not agree with everything, this is clearly a clean conception -- and mine, while (only) slighlty different, is quite similar.
For now, I have no direct objection to your design. Maybe the number of control voltages, or of input signals, might be different. Matter of taste.
Anyway, I *do* like the idea. Please go on !
Yours,
-- françois
PostPosted: Wed Oct 22, 2008 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just checked the actual prices on resistors (1% metal) at rockby, and found that they charge about 10 times the price of Jaycar. Unless you want to buy more than 1000 of a particular value. Rolling Eyes
Just not very realistic is it?
Luka
PostPosted: Wed Oct 22, 2008 5:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
there is also altronics and futurlec andy
seriously jaycar my last resort for anything
always costs me a fortune
problemchild
melbourne australia
PostPosted: Wed Oct 22, 2008 5:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I actually like Altronics the best at the moment.
