wasp vcf questions
Page 1 of 1 [23 Posts]
numbertalk
PostPosted: Tue Jul 08, 2008 12:05 pm    Post subject: wasp vcf questions Reply with quote  Mark this post and the followings unread
I've built several effects pedals and have decided to move onto my first synth project, which I've decided is going to be the JH Wasp VCF clone (http://modular.fonik.de/pdf/Wasp%20Filter%20clone.pdf). I have a few questions about this project. Some of these are things I just haven't encountered yet while building effects stompboxes.
1) What kind of jacks are the 3 that mount to the PCB with 4 terminals? Anyone have a Mouser part #?
2) To connect the 3 pots to the board, these are just 3 pin MTA connectors (.1" female cable mount Mouser part AMP 6404413 & .1" Male PCB mount Mouser part AMP 6404563), right?
3) What about the 16-pin connection in the bottom right - looks like the power connection? I tried looking on the data sheet for the 3 pin .1" MTA connectors for a 16 pin version but didn't see any - anyone have part numbers for the male and female connectors this requires?
4) If I wanted to power this project with 2 batteries while I'm building and testing, how would I wire it to the power connection? Is this possible? Guess this is part of why I'm confused with this connection having 16 pins - from the other modules I've looked at so far only 3 pins seem to be needed (one for + voltage, one for 0V and the third for - voltage).
5) Are P1 & P3 linear taper?
Thanks. I'm really looking forward to getting started building a synth.
jhaible
PostPosted: Tue Jul 08, 2008 4:06 pm    Post subject: Re: wasp vcf questions Reply with quote  Mark this post and the followings unread
Question
I'm not aware I've ever made a PCB, or suggested connectors for this ...
JH.
numbertalk
PostPosted: Tue Jul 08, 2008 6:47 pm    Post subject: Re: wasp vcf questions Reply with quote  Mark this post and the followings unread
Well, I guess this topic needs to be moved somewhere else then. The person who did create this PCB and spec, which I did include a link to in my posting, mentions his spec is based on your design (the documentation at the link I sent even has your name at the top). So, maybe I wasn't clear, but I wasn't suggesting you had ever made a PCB or suggested connectors for this module. Rather, I posted this topic here because I thought/hoped that the person who did adapt your design (or someone who has built this specific version of this module) might read this forum and might be able to help me out.
Anyway, I think I've figured most of it out. I found dual row 16 pin connectors but not at Mouser or anywhere else I usually order from. Not sure about the panel mount jacks that would connect correctly to this specific PCB either but based on that specific schematic it looks like each jack only actually connects to the circuit in 2 places, so it doesn't seem like they'd be switched or too difficult for me to work out how to wire up with solder lug mono jacks.
Question
JH.
jhaible
PostPosted: Tue Jul 08, 2008 10:49 pm    Post subject: Re: wasp vcf questions Reply with quote  Mark this post and the followings unread
I see.
JH.
Fetafarmer
PostPosted: Wed Jul 09, 2008 4:01 am    Post subject: Re: wasp vcf questions Reply with quote  Mark this post and the followings unread
Hi numbertalk. One thing you should consider is that you're not going to get a very exciting response from the filter without some kind of dynamic control: an envelope generator or follower, an LFO, etc. Jürgen did create a simple ADSR/LFO specifically for his Wasp design, and you'd probably want to build that, as well. I'm sure the schematic can be found on his website.
Another consideration for you is the probable difference in signal levels used/expected by this module vs. those of your effects pedals. This filter is probably optimized for 10V p-p, while your stompboxes probably deal with less than 2V p-p. In this case, a level shifting circuit, such as the CGS Stompbox Adapter, would be helpful.
You can use .100" headers, or just wire straight to the PCB itself. I use the Molex KK series myself (Mouser 538-22-23-2031 for example).
You don't need 16 pins at all. This circuit runs on a single supply, +5V (which the 7805 converts down from +15V), so you really only need two pins: one supplying +15V, and one for ground. The other connections to ground at that header can be wired to any pots or jacks that need a path to ground.
Kevin
PostPosted: Wed Jul 09, 2008 5:42 am    Post subject: Re: wasp vcf questions Reply with quote  Mark this post and the followings unread
most of your questions seem to have been answered already.
i made the PCB layout you're refereing to for my own purposes. the tracks are wide enough for press'n'peel blue process.
so what about the sockets? i use cliff sockets to mount the PCB to the front panel. they are not available from mouser.
the power connector is a ribbon connector as used by i.e. doepfer.
you can easily power the filter from a 9V cell. i tried this circuit with up to 15V. no problem at all. one of my favorite filters. i am currently working on a 2nd clone.
hope that helps.
numbertalk
PostPosted: Wed Jul 09, 2008 6:42 am    Post subject: Re: wasp vcf questions Reply with quote  Mark this post and the followings unread
Thanks for all the information! I actually do own some synth equipment - an MS50, MS20 and also a Moogerfooger CP251, so I do have some EG and modulation sources. Just to start building, before I have enough modules to stand alone, I plan to use them with my MS50.
It sounds like I don't need the 16 pin connectors but Fonik, just out of curiosity, where do you get those Doepfer connectors, because I looked online, on their website and at Analogue Haven (U.S. Doepfer dealer) but I couldn't find any part #s or places to get them.
One more question:
So just to check that I know how to do this (though it sounds like I could use just a single 9V battery), I could wire 2 9V batteries together like so: the positive connector from one battery goes to the +15V pin on the board, the negative of that battery as well as the positive of the 2nd battery both connect to the ground pin and then though the - voltage isn't used, the negative lead of the 2nd battery can be connected to the -15V pin. Would that be right? Basically something like this:
positive pin <battery> 0V pin <battery> negative pin
Thanks again.
Kevin
PostPosted: Wed Jul 09, 2008 8:18 am    Post subject: Re: wasp vcf questions Reply with quote  Mark this post and the followings unread
over here (in germany) you'll get them from almost any electronic components seller, they are quite common in europe.
Thanks again.
no need to do this. the module does not require a bipolar PSU. just connect one 9V cell: +pin of cell to +V of PCB and -pin of cell to GND.
you could even ignore the 5V regulator (install a jumper for the positive rail instead) and power the module from 9V.
numbertalk
PostPosted: Wed Jul 09, 2008 9:20 am    Post subject: Re: wasp vcf questions Reply with quote  Mark this post and the followings unread
So instead of the LM7805 I would put a jumper from where pin 1 to where pin 3 of the LM7805 would have been (crossing over but not connecting the ground line)?
Also, you mention on your web site that in the documentation P3 (potentiometer for resonance control) is accidentally reversed - just making sure this is still the case and that I should reverse the wiring for this one.
Thanks again.
numbertalk
PostPosted: Wed Jul 09, 2008 10:13 am    Post subject: Re: wasp vcf questions Reply with quote  Mark this post and the followings unread
Also curious, what's the part # for the Cliff Sockets you use? Is it the S1?
Thanks again.
PostPosted: Wed Jul 09, 2008 11:45 am    Post subject: Re: wasp vcf questions Reply with quote  Mark this post and the followings unread
yep!
it is still the case. Shocked
numbertalk
PostPosted: Wed Jul 09, 2008 11:47 am    Post subject: Re: wasp vcf questions Reply with quote  Mark this post and the followings unread
Great, thanks again for all the help. Think I'm good to go.
fonik wrote:
yep!
PostPosted: Wed Jul 09, 2008 11:55 am    Post subject: Re: wasp vcf questions Reply with quote  Mark this post and the followings unread
i use the CL1384(1). this would be the part number to the cliff catalogue. you will get them from farnell, i guess, and/or from cliff directly.
this is the socket most of the modular systems in euro or frakrack format use, IIRC.
numbertalk
PostPosted: Wed Jul 09, 2008 12:49 pm    Post subject: Re: wasp vcf questions Reply with quote  Mark this post and the followings unread
Thanks again. Looks like these aren't readily available in the states.
PostPosted: Wed Jul 09, 2008 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.cliffusa.com/content.asp?PID=7&Page=2
numbertalk
PostPosted: Wed Jul 09, 2008 6:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, I didn't realize I could get them directly from Cliff - I'll get in touch with them. Thanks again.
PostPosted: Thu Jul 10, 2008 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
good luck.
farnell stocks the version with solder lugs only (CL1382).
numbertalk
PostPosted: Tue Aug 05, 2008 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
EDIT - Fixed it! Was a bum chip. Works and sounds fantastic.
moosapotamus
PostPosted: Mon Aug 18, 2008 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I know that in the Wasp circuit the distortion section is intentionally located after the filter. But, would it be worth adding one additional switch to also have the option of switching the distortion before the filter (pre or post distortion)? Or rather, just replace the distortion toggle with a rotary switch wired up to give pre/off/post settings for the distortion? And maybe also make the feedback resistance (R24) variable to adjust the amount of distortion?
Or, maybe I should just breadboard it and find out for myself?! Razz
~ Charlie
moosapotamus.net
"I tend to like anything that I think sounds good"
PostPosted: Tue Aug 19, 2008 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
~ Charlie
what i did was to bring the distortions in and out to the frontpanel (but it is normalized using switching sockets). i build a three stage distortion circuit (seb francis box-o-trix cmos distortion circuit) and added a switch to select the number of stages. the IC is getting fairly hot, but not hotter than 60°C. finally i added a simple wet/dry mix and brought the inputs and the output to the panel, too:
moosapotamus
PostPosted: Wed Aug 20, 2008 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
That looks pretty cool, fonik.
So if you want, you can patch the distortion either before or after the filter?
What's the normal/krank switch do?
~ Charlie
moosapotamus.net
PostPosted: Wed Aug 20, 2008 5:41 am    Post subject: Reply with quote  Mark this post and the followings unread
sure
not that've used the filter much yet. i still have to tweak the cutoff control (i implemented an expo control, not the linear one, which makes juergens clone unique...
~ Charlie
the krank/normal control switches the diodes in the resonnance feedback path. you choose between 1n4148 (normal) and green LEDs (krank) which increase the clipping.
moosapotamus
PostPosted: Wed Aug 20, 2008 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool
~ Charlie
moosapotamus.net
