Small footprint pots? Little blue plastic square backs?
Page 1 of 1 [8 Posts]
ericcoleridge
PostPosted: Thu Oct 09, 2008 8:32 pm    Post subject: Small footprint pots? Little blue plastic square backs?
Subject description: Can someone tell me where to get these kind of pots-- pictured
I need to find some very small backed pots and I've seen these particular ones on Thomas Whites "Natural Rhythm" site and elsewhere. Pictured here:
Just wondering what kind/where to find them; Also, if they're smaller than the little Alpha pots Futurlec sells (what I already have)?
urbanscallywag
PostPosted: Thu Oct 09, 2008 9:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Aren't they Bourns 90 series?
http://www.bourns.com/pdfs/90SERS.pdf
djthomaswhite
PostPosted: Fri Oct 10, 2008 1:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, those are the Bourns 91A series. Very loose feeling compared to Spectrol/Vishay, but they don'e get any looser with use like Vishay/Spectrol. Now they are actually cheaper than the Spectrol 248/148 series. Allied Elec has them I think. I have found them on eBay before too.
Thomas
Thomas
www.naturalrhythmmusic.com/diy.html
/mr
PostPosted: Fri Oct 10, 2008 3:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Bourns series 90 (used in MOTM) is not very small (16*18mm)
compared to for example Bourns series 50 (13*13mm).
I'm planning to use the wonderfully dampened metal-shafted 50 instead of the way too loose plastic 90.
Here is a picture of a 51 and a 91, both with MOTM-sized knobs (PKES90):
 Filesize:  83.32 KB
 Viewed:  2430 Time(s)
BananaPlug
PostPosted: Fri Oct 10, 2008 6:50 am    Post subject: Reply with quote  Mark this post and the followings unread
FYI, last time I tried to actually buy some of those small Bourns pots nobody had stock or would sell in small quantities. If you find a good source please let us know.
ericcoleridge
PostPosted: Fri Oct 10, 2008 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, this smaller Bournes 50 is exactly what I need-- thank you very much for pointing it out. Very nice.
I figured these-- pictured Bournes pots above-- were a common species. I've seen them in many peoples' projects-- but I've just never looked further than the $0.50 small Alphas offered by Futurlec. But now I need something even smaller.
I wonder, if the Bournes 50 is indeed unavailable, if there is a Spectral pot, for instance, with similar specs, size, etc.
ericcoleridge
PostPosted: Fri Oct 10, 2008 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Incidentally, here's a link to the Bournes product page, with all their panel control pots (you may have to cut and paste it):
http://www.bourns.com/components.aspx?cmsphid=7631383|7163299|4003686#cpc
However, I'm having a little trouble finding either the 51/53 or 90 series at Mouser or Allied.
/mr
PostPosted: Fri Oct 10, 2008 7:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
True, they are not easy to find, especially in small quantities. But they are almost too expensive in small quantities anyway. Smile
Digi-Key and Farnell seem to stock some models in single quantities though (on this side of the Atlantic pond), and Mouser.
