calculating 3rds
Page 1 of 1 [11 Posts]
tayholliday
PostPosted: Thu Nov 20, 2008 9:58 am    Post subject: calculating 3rds Reply with quote  Mark this post and the followings unread
I'm trying to implement a diatonic harmonizer.
Given a scale and a note value, how can I calculate the note value of, say, a 3rd up in the scale?
I have a few ideas but they all seem rather ugly to implement. One way which might make for a nice interface, is to map the current note to a step in the note sequencer, which in turn would give me the correct output note. Seems like the only way to get a sequencer to a particular step is to reset it and give it N clock pulses, which I'm not sure how to do.
thanks!
ark
G2 patch files: 31
PostPosted: Thu Nov 20, 2008 10:26 am    Post subject: Re: calculating 3rds Reply with quote  Mark this post and the followings unread
In equal temperament, you go up a minor third by multiplying the frequency by the fourth root of 2; you go up a major third by multiplying the frequency by the cube root of 2.
tayholliday
PostPosted: Thu Nov 20, 2008 10:37 am    Post subject: Re: calculating 3rds Reply with quote  Mark this post and the followings unread
Right, but I'm implementing a diatonic harmonizer, so I need some logic to decide which interval to use (maj3, min3), depending on the note I'm playing.
Oh, and I'm trying to do this for guitar, so I'm using the pitch track module to determine the note I'm playing.
ark
G2 patch files: 31
PostPosted: Thu Nov 20, 2008 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Won't a key quantizer do most of what you want?
tayholliday
PostPosted: Thu Nov 20, 2008 11:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I was thinking about that... but I'm not sure how to apply it. Adding a fixed number of semitones (3 for min3, 4 for maj3) and then quantizing only gets it right half of the time. I still need a way of choosing which interval to use based on the current note. Really, it would be cool to have an arbitrary 1 octave note -> note mapping.
ark
G2 patch files: 31
PostPosted: Thu Nov 20, 2008 11:32 am    Post subject: Reply with quote  Mark this post and the followings unread
What happens if you add 3.5 semitones?
tayholliday
PostPosted: Thu Nov 20, 2008 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok for Cmaj:
C -> half way between D# and E -> quantized to E
D -> between F and F# -> quantized to F
E -> between G and G# -> quantized to G
F -> between G # and A -> quantized to A
G -> B
A -> C
B -> D
voila... you're a genius ark! Very Happy
Now, can I actually add 3.5 to a control signal? I thought they were integers.
ark
G2 patch files: 31
PostPosted: Thu Nov 20, 2008 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
They're not integers. See attached patch.
Thirds.pch2
 Filename:  Thirds.pch2
 Filesize:  1.29 KB
 Downloaded:  1526 Time(s)
tayholliday
PostPosted: Thu Nov 20, 2008 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
ark wrote:
See attached patch.
Awesome. Now to do the shift on audio input, I guess I just use the difference between the two pitches as the shift amount?
ark
G2 patch files: 31
PostPosted: Thu Nov 20, 2008 12:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would think.
tayholliday
PostPosted: Fri Nov 21, 2008 6:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's my stab at harmonizing 3rds from audio in. It sounded quite good to me with my guitar Smile
Thanks again ark.
Diatonic3rds.pch2
Harmonizes a maj3 or a min3 depending on which note you play.
 Filename:  Diatonic3rds.pch2
 Filesize:  1.81 KB
 Downloaded:  1368 Time(s)
