What are those Wave "flaws" which keep getting mentioned?
Page 1 of 1 [18 Posts]
purusha
PostPosted: Wed Apr 15, 2009 1:07 am    Post subject: What are those Wave "flaws" which keep getting mentioned? Reply with quote  Mark this post and the followings unread
Can anyone give me a quick run-down on what the main shortcomings are?
I'm half-considering buying a Wave as replacement for my Korg Triton. I don't need the work-station side of things. I'm more interested in the on-stage useful-ness of the machine.
Any thoughts/opinions!?
Chris
OVNI Soundcloud Purusha Soundcloud
Oli
PostPosted: Wed Apr 15, 2009 3:25 am    Post subject: Re: What are those Wave "flaws" which keep getting mentioned? Reply with quote  Mark this post and the followings unread
Hi Chris,
I have only ever played with the Wave in a shop a few times, but I can offer a couple of thoughts anyway.
I really suggest you also take a few leasurely trips to your local music store, and see if the control surface does what you want from a live set. I guess you may not have a chance to use the waveforms you would want, but it should give you some idea.
In terms of shortcomings referred to, I think this is probably in relation to the Lead 3 and Modular G2 features, which are not available in the Wave (not too sure though). For example, I think people have complained about the lack of a unison stack as featured in the Lead 3. I guess people just hoped for more from a synth that has good fundamentals.
I think the Wave will be pretty different from the Trinity, but I guess you know that. At least, if you are used to using effects, you may need to get an external processor. I haven't explored the Wave effects, but from memory the Trinity was pretty well featured in this regard.
Hope it helps.
Good good study, day day up!
purusha
PostPosted: Wed Apr 15, 2009 6:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the input.
Guess I'm after finding out what the non-obvious niggles are.
Wink
gearaholic
PostPosted: Wed Apr 15, 2009 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
2 slots instead of 4
wheel and pedal morph tied together
no unison detune
no split
after touch only for vibrato
not enuff memory for entire mellotron library
no inversion of filter env,mod env or lfo amount
other than that im happy
ark
G2 patch files: 31
PostPosted: Thu Apr 16, 2009 9:20 am    Post subject: Reply with quote  Mark this post and the followings unread
When you turn a knob, the corresponding parameter jumps immediately to the knob setting, which might cause an abrupt change in sound.
No way to change the contents of patch memory without a computer, which, when coupled with the fact that patch memory isn't big enough to contain the whole factory library, means that you cannot escape from using a computer if you want the full flexibility of the synth.
But I don't think there's a patch editor, just a sample editor--which means that you still have to use the knobs for patch editing, despite the jump behavior mentioned earlier.
When people were selling the Wave for $2700, I thought it was way overpriced.
Now that they are selling it for $1700, I've given it a lot of thought but still decided not to buy one.
If they came out with a new Wave with a real modulation matrix, G2-style rotary encoders, and the ability to load samples from a CF card without using a computer, I'd pay $3,000 for it in a heartbeat.
redkey
PostPosted: Thu Apr 16, 2009 12:50 pm    Post subject: Very happy Wave owner Reply with quote  Mark this post and the followings unread
All of the above comments are valid. To have two slots and not be able to split the keyboard is a real pain. The onboard effects are limited, but sound beautiful. The Chorus (3 types) and Delay are individual per slot. Tube overdrive and Reverb are at the Program level. This means that you can't have slot A with OD and B without.
A big thing is that Programs and Samples are not tied together. If you moves samples to a new location, replace them, or delete them, the Program will not know. It will flash if the sample slot is empty and the program was expecting one. But if you replace a piano sample with a horn sample, your Programs that used the piano sample will now sound like horns.
All this aside.....
The Wave is one of the most expressive and beautiful sounding synths I've had the pleasure to use. I use it live and it cuts through a mix so well. At the same time, the pads, vocals, and strings can compete with software like Atmosphere. Every complaint about the lack of endless encoders is handled (for me) through setting up Morphs which are brilliant. It is fast, responsive, expressive, inspiring, motivating, etc.
I love mine so much I want another. I also let an artist have his way with it last month.
http://web.me.com/danielpatten/NordWave
Feel free to ask any additional questions.
Best,
RedKey
Ivan
PostPosted: Thu Apr 16, 2009 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
there's no velocity layering of samples.
purusha
PostPosted: Mon Apr 20, 2009 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the comments guys.
I guess that's put me on the fence for a while.
Wink
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Apr 20, 2009 3:57 am    Post subject: Reply with quote  Mark this post and the followings unread
purusha wrote:
... I guess that's put me on the fence for a while. Wink
Coward!
Wink
Wout
purusha
PostPosted: Mon Apr 20, 2009 4:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Yellow through and through.
Wink
Oli
PostPosted: Wed Apr 22, 2009 10:17 am    Post subject: Re: Very happy Wave owner Reply with quote  Mark this post and the followings unread
redkey wrote:
...I also let an artist have his way with it last month...
Hey, nice job there. I was cringing a bit when I read this. I've seen some really unprofessional attempts at this sort of thing. From the photos, it looks like a pretty slick job, and the result holds together nicely.
Thanks for posting the link.
purusha
PostPosted: Wed Apr 29, 2009 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm.
I've been giving this some serious consideration and am starting to feel the tug of this bit of kit.
Looking at the way things have been and are going for me musically, it's possible that it might actually be very useful for me.
I could get those old Mellotron sounds etc. via M-Tron Pro or a sample-set for my Triton (Mellotron sound is definitely something I'm interested in). However, I've recently found myself spending more time playing on-stage as an add-on for other acts (guitar and synths), so a keyboard with the Wave's feature set is more appealing that a bunch of soft-synths.
It is very expensive though, which is the factor that's putting me off...
redkey
PostPosted: Wed Apr 29, 2009 5:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Worth every penny of $2500US I paid a year ago.
Now you can get new ones for $1699 at novamusik.com.
I own both a wave & M-tron pro. The wave is far more musical and expressive. And the ease of grabbing your board and going out compared to programming your laptop for hours (exaggerating) bringing out your laptop, audio interface, MIDI interface, USB keyboard, and hope it doesn't crash........
Enjoy the hunt.
purusha
PostPosted: Wed Apr 29, 2009 6:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm in the UK though, where pretty-much everyone wants £1600 for a Wave.
Gulp!
purusha
PostPosted: Thu Apr 30, 2009 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well - I've now got a Wave in my setup.
There's a few disappointments, but it's so easy to program.
It's great how easy it is to get a sample set in there.
It'd be nice if the sample editor would convert sample rates though. I'm having to batch process stuff via Wavelab, which isn't too bad, but it's an extra arguably un-necessary step.
The effects are surprisinly limited in terms of parameters, but they do the job and sound good.
It's a shame Nord don't use their USB ports for MIDI too. Means more un-necessary cabling.
Carbon111
PostPosted: Thu Apr 30, 2009 4:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
The only really annoying limitation is the aftertouch being hardwired to vibrato.
Other than that niggle, I absolutely love mine for its weird other-worldly timbres and ease of programming.
This demo I did is all Nord Wave: http://www.carbon111.com/nord_wave/wave_demo.mp3
Audio files: 297
PostPosted: Thu Apr 30, 2009 6:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Carbon111 wrote:
This demo I did is
Nice demo!
purusha
PostPosted: Fri May 01, 2009 12:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't mind that since it's the way I typically configure my patches on my synths.
I don't think the aftertouch mechanism on the keyboard itself is as controllable as the one on my NL3 though. It feels a bit on/off.
