purusha
iPassenger
Joined: Jan 27, 2007 Posts: 1068 Location: Sheffield, UK
G2 patch files: 78
Posted: Thu Apr 02, 2009 10:42 am Post subject:
I can't connect via a hub from my OSX system to the G2 Engine. Starts breaking up pretty quickly. There have been several reports of similar hub issues here in the past, I think.
Joined: Jan 31, 2003 Posts: 18235 Location: Durham, NC
Audio files: 222
Posted: Thu Apr 02, 2009 12:48 pm Post subject:
USB, especially USB2m and Firewire have similar problems. There is an industry standard, but different chip makers interpret the standards differently, and software driver writers do as well. It is known that MOTU devices will only work with certain chips in the computer. One should expect this with incompatibility problem USB2 as well.
Unfortunately, except for more responsible companies, like MOTU and RME, most companies don't acknowledge this incompatibility problem, nor do they test the USB interfaces carefully.
Fortunately, the computer interfaces and hubs are relatively cheap, so can try another one. Not so easy if the USB or Firewire interfaces in your laptop don't work. _________________ --Howard
my music and other stuff |
iPassenger
G2 patch files: 78
Posted: Thu Apr 02, 2009 2:03 pm Post subject:
mosc wrote: | USB, especially USB2m and Firewire have similar problems. There is an industry standard, but different chip makers interpret the standards differently, and software driver writers do as well. |
Hehe.. ^^^this makes a lot of sense. _________________ iP (Ross)
Audio files: 222
Posted: Thu Apr 02, 2009 3:11 pm Post subject:
I can't pass up the opportunity to tell another story. Long ago in a different universe I was in charge of a big distributed computing network at Lucent. Every engineer has a big Sun workstation for their CAD. They were refurnishing a design center and we put in the new 10baseT hubs and routers made by AT&T, the latest stuff. It used our chips.
When we moved an analog IC design group into the new digs, they started to complain that there was something wrong with the network - their simulations were taking much longer then at the other place where they were on coax networks.
We did everything we could think of to fix this problem. But it was a tough one, there were no errors anywhere indicating what the problem was. We swapped out hubs and even rewired one guy's (the most vocal) office. I'll call him Satan, for this example. Nothing. We had network analyzer vendors come in an I promised them I'd by 25 analyzers if they could spot the problem. Nothing.
Satan started bad mouthing our department and me in particular. His message to my boss was that I didn't know anything about networks and they should outsource our entire department. My boss told me he was getting tremendous pressure to thump me. I was getting worried.
Then a few days later, I get one of those "see me immediately" messages from my boss. Arrggg...
It turns out that Satan was a very respected member of the design community in Bell Labs. He personally designed the 10baseT chips in the AT&T hubs we were using. He got so fed up with us that he decided to solve the problem himself. He hung a storage scope right on the network wires coming from his office. He saw stuff he that shouldn't have been there. Something was wrong.
It turns out, the routers we were using the computer room were made by DEC, a different company, of course, who used their own chip. That chip had been on the market for several years. They were doing something that Satan never expected, but still consistent with the standard, just something that didn't occur to him could be. It was something the trailer shall be no less than 3 clock cycles. He made his chip work with 3 but not more. The DEC chip would send the trailer for 3, 4, sometimes, 5 clock cycles - consistent with standard. It was a design error made by himself.
My boss was so happy for two reasons: 1) he didn't have to fire me and my department, and 2) we learned about a serious problem in the AT&T devices before the customers. It probably saved an entire division of the company.
Satan never apologized BTW, and every time he passed me in the hall he looked the other way. In our department, whenever we talked about FUs, we called them by his first name, which wasn't Satan if I remember correctly.
This is a good lesson to learn though. Standards are complicated and there are very few industry compliance tests.
Brings to mind a line from a poem by Kipling.
If you can keep your head when all about you,
Are loosing theirs and blaming it on you. _________________ --Howard
drapdap
Posted: Fri Apr 03, 2009 11:05 am Post subject:
If!
i love to read stories such as this from You Howard.
r. |
cbm
Joined: Oct 25, 2005 Posts: 381 Location: San Francisco
Posted: Fri Apr 03, 2009 12:26 pm Post subject:
Trying a different hub is a good idea.
At one point in the dim dark past, I thought that some revision of emagic's Logic was the most crash-prone piece of software I had ever used. Other people weren't having problems with it, so I started to think that what was wrong with my system was hardware. After swapping memory out, and a bunch of other stuff, it occurred to me that I had added a new hub at about the same time, and that Logic's USB dongle was plugged into this hub. I got a new hub and all my problems went away. _________________ Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job) |
GovernorSilver
Joined: Apr 26, 2004 Posts: 1349 Location: Washington DC Metro
Posted: Fri Apr 03, 2009 2:59 pm Post subject:
Maybe a new sticky thread should be started in which users report "good" USB hubs to use with G2 Editor?
I remember a thread about good/bad USB hubs on the daw-mac group a few years ago. _________________ Current and recent work on Soundcloud
Some old stuff on VIRB |
cbm
Posted: Fri Apr 03, 2009 4:16 pm Post subject:
GovernorSilver wrote: | Maybe a new sticky thread should be started in which users report "good" USB hubs to use with G2 Editor?. |
I don't have a G2, so I can't help with that, but the hub I ended up with, which seems bulletproof, is this Adaptec XHub7+:
http://www.amazon.com/Adaptec-AUH-7000PLUS-XHub7-USB-Port/dp/B000062SU0 _________________ Chris Muir
Posted: Sun Apr 05, 2009 2:03 pm Post subject:
My bandmate is having this problem with firewire and a presonus device...he bought a bleeding edge laptop form Dell that just doesn't seem happy with the audio interface.
He's currently shopping for PCI/PCIe firewire cards...something tuned & compatible with the firewire device. So, that may be an option. I know RME makes their own Firewire card, that is supposedly highly tuned for their devices...no problem (as long as PCIe is playing nicely!). |
BorisZuev
Joined: Apr 18, 2009 Posts: 8 Location: ST.PETERSBURG
Posted: Sat Apr 18, 2009 7:54 pm Post subject:
Re: Nord Editor 1.6 bug? Subject description: MORE OVER AFTER INSTALLATION 1.62 IT CORRUPTED MANY BANKS-IALSO SWITCH IT AGAIN AND AGAIN -WHEN SAVI |
CoolAngel wrote: | Hello to all,
are the new forum, I have now installed the new driver and the new editor for my G2 is on XP or on Vista (2 computers where it was not installed the driver and the editor of the previous G2) .. and I noticed in both cases that if you open the editor for the first time everything works fine, but if you close the editor and reopened several times this is blocked and you turn off and on the G2 . Someone had this problem? Thank you
P.S. Sorry my bad English |
BorisZuev
Posted: Sat Apr 18, 2009 8:08 pm Post subject:
UPDATE 1.62 Subject description: IS A REAL HEAD ACHE FOR MY G2 |
AFTER INSTALLING NEW DRIVER 1.62 ON MY MAC BOOK PRO -FROM THE NEWEST ONES - I WAS TIRED SWITcHING ON&OFF IT CORRUPTED SOME BANKS /WHILE MAKING SAve/driver 1.40 worked well -but i/ve deleted it ? |
BorisZuev
Posted: Sat Apr 18, 2009 11:18 pm Post subject:
G2 1.62 UPGRADE Subject description: UPGRADE-CORRUPTER |
NOT TO FIX I MY CASE-BUT TO BRING THE BUG-I HAVE UPGRADED TO1.62-
I HAVE TWO MONTH MAC BOOK PRO & MY G2 SUCCESFULLY WORKED UNTILL THIS UPPGRADE - IT HAS CORRUPTED MANY PATCHES AND AFTER 10-15 TIMES I SAVE MY WORK IT FREEZES I REINSTALLED TWICE 1.62 THE PROBLEM REALLY EXISTS..... MAY BE SOMEBODY KNEW HOW TO IMPROVE THIS ? |
peterkadar
Joined: Jan 11, 2009 Posts: 152 Location: Toronto, Canada
Posted: Sat Apr 18, 2009 11:51 pm Post subject:
Man, I hope you get everything sorted out soon...
Mosc, I really dig your story too!
Hope everyone's well. I've got some new (ish) things in store for the G2 community in the not too distant future  |
Static Motion
Posted: Sun Apr 19, 2009 3:03 pm Post subject:
I'm having more & more corrupt patches since i updated to the new OS on mac-intel 10.4.11.
When saving in the G2's internal memory, it freezes, and i have to switch it off to get it to work again...the patches saved are all corrupted.
I save them on my computer also via the editor, and those patches are ok.
Anyone having the same problem ? |
gomidas
Joined: Jul 09, 2004 Posts: 365 Location: La Ciotat, France
G2 patch files: 6
Posted: Mon Apr 20, 2009 12:28 am Post subject:
Static Motion wrote: | I'm having more & more corrupt patches since i updated to the new OS on mac-intel 10.4.11.
EVERYONE
JUST GO BACK TO SYNTH OS 1.40 (1.6 WAS THE LAST JOKE FROM CLAVIA BECAUSE WE WERE BEGGING SO HARD FOR AN INTEL EDITOR) AND USE THE 1.6 INTEL EDITOR, EVERYTHING SHOULD BE FINE THEN. |
Static Motion
Posted: Mon Apr 20, 2009 3:28 am Post subject:
Where can I find 1.40 for osx ? |
Joined: Apr 03, 2004 Posts: 24391 Location: The Netherlands, Enschede
Audio files: 296
Posted: Mon Apr 20, 2009 2:14 pm Post subject:
Static Motion wrote: | Where can I find 1.40 for osx ? |
I know you found it, but just for completion
http://electro-music.com/forum/topic-32310-25.html _________________ Jan
BorisZuev
Posted: Tue Apr 21, 2009 1:20 pm Post subject:
IS IT POSSIBLE TO IMPROVE CORRUPTION SOMEHOW / Subject description: CORRUPTION CONTINUED |
IS IT POSSIBLE TO USE 1.40 AFTER 1.62 CAUSE IT WORKED WELL ON MY MAC BOOK PRO OS X.5.6/ SO
I HAD PREPARED PATCHES FOR TOMMOROW/S CONCERT /
THEY HAVE BEEN
-GOD BLESS MYSELF -AND ALL OF YOU MY DEAR FRIENDS AND CLAVIA TOO OF COURSE -
- PRE SAVED IN COMPUTER AND I CAN USE THEM -BUT WHEN I DECIDED TO CHECK THEM NOW -MOST OF THEM AGAIN WERE CORRUPTED
I FEEL THIS BUG EXISTS IN 1.62 NOT IN THE HUBS ETC....
RESPECT FOR THOSE WHO KNOW ! |
Audio files: 296
Posted: Tue Apr 21, 2009 1:31 pm Post subject:
Boris ... I understand you are unhappy and confused, but by using regular capitalization your message would be more pleasant to read  _________________ Jan
gomidas
G2 patch files: 6
Posted: Tue Apr 21, 2009 1:55 pm Post subject:
Re: IS IT POSSIBLE TO IMPROVE CORRUPTION SOMEHOW / Subject description: CORRUPTION CONTINUED |
BorisZuev wrote: | IS IT POSSIBLE TO USE 1.40 AFTER 1.62 CAUSE IT WORKED WELL ON MY MAC BOOK PRO OS X.5.6/ SO
THEY HAVE BEEN
YES
BEST
Gomi |
Audio files: 296
Posted: Tue Apr 21, 2009 1:57 pm Post subject:
gomidas wrote: | YES |
BorisZuev
Posted: Tue Apr 21, 2009 2:27 pm Post subject:
Thanks Subject description: Am I right now Jan ? |
I knew - lord exists / I have made upgrade 1.40 -tommorow i will try....Thanks |
cl516
Posted: Sun Apr 26, 2009 8:25 am Post subject:
i'm about to pickup a G2 engine:
so what's the word,
Use 1.40 for the Synth OS
and use the 1.62 Editor?
The computers I'll be using it with will be:
Mac Pro and White Macbook,
will not be plugging into any Hubs. _________________ http://cl516.blogspot.com |
