pauldirks
Joined: Dec 19, 2005 Posts: 24 Location: vancouver, bc
Posted: Tue Jul 21, 2009 10:37 pm Post subject:
Driver problems with new motherboard |
Hi Everyone,
Looking for some ideas for a driver problem with a G2 (engine)
I installed a new motherboard in an XP machine- I've got everything else up and running except for the G2. When I install hardware the PC hangs when installing the driver to the system32/drivers folder.
I then tried installing the newer version with its USB driver and same thing. Stuck PC. I've now tried every variation of install/uninstall/reinstall I can think of between the two versions. Any ideas?
Paul _________________ ------------
Bishop & Mulholland- Electro Soul
https://soundcloud.com/bishopandmulholland
Nord G2 Keyboard
E6400 Sampler (2)
Cubase, RME Hardware |
dasz
Audio files: 29
G2 patch files: 56
Posted: Mon Jul 27, 2009 8:53 am Post subject:
if nothing else works on your machine, try a USB hub.
Are you using v1.4?
/Dasz |
pauldirks
Posted: Mon Jul 27, 2009 11:55 am Post subject:
Hey dasz! Thanks for the suggestion. I'll try that. I was using 1.4- couldn't get it to work and hopefully tried the new 1.62 which didn't work either.
Thanks,
Nord G2 Keyboard
E6400 Sampler (2)
Chrono
Audio files: 37
G2 patch files: 38
Posted: Tue Jul 28, 2009 6:16 am Post subject:
| did you reinstall windows as well after installing the mainboard? |
pauldirks
Posted: Tue Jul 28, 2009 8:03 am Post subject:
Yes- I did. Any suggestions based on that? _________________ ------------
Nord G2 Keyboard
E6400 Sampler (2)
Chrono
Audio files: 37
G2 patch files: 38
Posted: Fri Jul 31, 2009 6:07 am Post subject:
hmm its just strange everything works except for the g2. its sad if you need to reinstall windows again and it doesnt work either.
Maybe you could mail nord and ask them if this could be a hardware related issue.
Or try find other (newer) drivers for the mainboard.
Maybe its an USB driver/cable issue.
Hope someone has any better suggestions for you. |
pauldirks
Posted: Fri Jul 31, 2009 6:58 am Post subject:
Thanks for the thoughts Chrono. I haven't looked at it for a couple days- scared of wasting another couple hours without getting it going I guess. But I'm completely hosed without the G2- it's at the center of everything here. Going to try a few more things here in the next couple days- then maybe try to contact Clavia.
Thanks. _________________ ------------
Nord G2 Keyboard
E6400 Sampler (2)
dasz
Audio files: 29
G2 patch files: 56
Posted: Fri Jul 31, 2009 8:35 am Post subject:
have you tried it on another computer?
/Dasz |
pauldirks
Posted: Fri Jul 31, 2009 9:06 am Post subject:
hmmm...actually no. I guess I'm assuming that it's a software issue to do with drivers and my computer. I would assume it would work and install on another computer- but I should try that to rule out (gulp...) a hardware issue or a G2-specific problem.
Nord G2 Keyboard
E6400 Sampler (2)
