SDS3 Single Voice PCB Run
Page 7 of 10 [245 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 Next
Oli
PostPosted: Tue Jul 21, 2009 10:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hm, he hasn't posted since May, and his site hasn't updated since April.
Does anyone know him well? Hope nothing is amiss.
edit - I would feel a bit uncomfortable about pm/emailing him; I wouldn't want to appear to hassle him over a DIY project. If someone here knows him better, it might be worth checking if everything is OK.
Good good study, day day up!
PostPosted: Thu Jul 30, 2009 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
hello david,
i hope you are well? PM'd you.
any news?
Coriolis
PostPosted: Thu Jul 30, 2009 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah forget SDIY - are you allright man?
C
PostPosted: Fri Aug 07, 2009 2:45 am    Post subject: Reply with quote  Mark this post and the followings unread
i recently contacted david. this kind and polite fellow is VERY busy at the moment. we agreed that i could take this project over if i wanted to.
this would mean a new start, since i wanted to use different developing tools and whatsoever. and i don't wanted to read this hole thread over again. so i would start redrawing the schematic tomorrow, breadboard it later, and all the steps. that will take a little while and i have some other irons in the fire.
what do you guys think?
Sound
PostPosted: Fri Aug 07, 2009 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
I think good Fonik, go ahead, 4 PCB here Thanks.
The best to David. Thanks for start this project. Hope You will be less busy in a future and come back to E-M.
Hug.
whomper
PostPosted: Fri Aug 07, 2009 3:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Looking forward for the restart.
I hope you'll be able to offer it in the similar price range that David offered.
4 for me.
Erez Yaary
Buy my CDs at http://www.mellowjet.de
diablojoy
PostPosted: Fri Aug 07, 2009 3:41 am    Post subject: Reply with quote  Mark this post and the followings unread
yes i would definetely be in for 4
good to see this continues
TekniK
PostPosted: Fri Aug 07, 2009 3:48 am    Post subject: Reply with quote  Mark this post and the followings unread
go ahead,i buy 6 or more for sure
(but have to be the same)
hope everything is fine with the guy
a.b.o.z.
G2 patch files: 4
PostPosted: Fri Aug 07, 2009 4:03 am    Post subject: Reply with quote  Mark this post and the followings unread
That is great Mathias.
But what about single sided etch it your self layouts?
PostPosted: Fri Aug 07, 2009 4:12 am    Post subject: Reply with quote  Mark this post and the followings unread
i will have to check it out first. i don't want to commit myself to this.
BTW has there been a feature list for the boards? i don't wanted to discuss this again, but i think there has been an agreement!?
Oli
PostPosted: Fri Aug 07, 2009 4:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I think it's great if you can restart the project.
Maybe a new thread is in order, and this one could be closed?
Personally, I wouldn't do a single sided board. It places too much constraint on the design process. Also, ground planes on each layer usually makes the design process faster, simpler, easier, and in most cases gives a better result. I think for the number of people signing on to the thread, a bulk buy of double layer, plated through hole boards is also economical.
How do people here feel about surface mount soldering? Personally, I much prefer it. I find it easier, and faster, most parts are easier to find in SMT, and the boards are smaller and cheaper. I know it's not popular for many DIYers though.
PostPosted: Fri Aug 07, 2009 4:37 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you for your suggestions, oli.
i would do it as i usually do it: double-layer board with ground-planes, plated-thru-hole.
the single-sided version would be an additional option.
Oli
PostPosted: Fri Aug 07, 2009 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, cool, I see.
Luka
PostPosted: Fri Aug 07, 2009 5:14 am    Post subject: Reply with quote  Mark this post and the followings unread
minimal smt thanks
please do take over this pcb dev. matthias
problemchild
melbourne australia
TekniK
PostPosted: Fri Aug 07, 2009 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
The problem,its that it will guaranteed change the sound,there are bad ca3080 in this project note..
all control pots on-pcb on this one would be cool
vtl5c3
PostPosted: Fri Aug 07, 2009 7:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Great news! Thank you for adding new momentum to this project, Fonik!
creatorlars
PostPosted: Fri Aug 07, 2009 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm definitely down! Board mounted pots for euro or frac would be awesome.
Danno Gee Ray
PostPosted: Fri Aug 07, 2009 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, Mathias, Please take the flag and press on. I too would be interested in multiples in Frac / Euro size.
Thanks,
and please convey best wishes to David. Hope all is well with him.
Peake
PostPosted: Fri Aug 07, 2009 3:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
CA3080 are still $1.29 each; check eeedesigner on ebay, or see the parts store section of an ebay search for CA3080.
Good work Fonik, I'm still interested!
TekniK
PostPosted: Sat Aug 08, 2009 1:05 am    Post subject: Reply with quote  Mark this post and the followings unread
i did mean ,there are 'bad' spec CA3080 on this board and as far as i know there are no smd versions of it,so to maintain sound need those same 'bad' 3080 Smile
Oli
PostPosted: Sat Aug 08, 2009 3:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Using SMT where available, doesn't require the entire board to be SMT.
Are you sure it is necessary to duplicate all characteristics of the original?
I don't think it is usually worth worrying about the effect of differences between leaded vs SMT resistor packages, for example. Unless there are particularly extreme signal conditions, it's unlikely to hear any detriment to the sound.
Use of legacy components is another matter.
I would think that if people don't like soldering SMT components, then that would be a pretty good reason not to use them, though.
TekniK
PostPosted: Sat Aug 08, 2009 11:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Its because this project will bring a pcb with the original characteristics explains the huge demand for pcb's atm
b-funk
PostPosted: Sun Aug 09, 2009 1:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually CA3080 ARE available in SMT...
http://cgi.ebay.de/50pcs-HARRIS-CA3080m-CA3080-M-SMD-ANALOG-OP-AMP-IC-H_W0QQitemZ120290764061QQcmdZViewItemQQptZGuitar_Accessories?hash=item1c01e3651d&_trksid=p3286.c0.m14
The more I think about it, the more I like the idea of a SMT board...
Greetz,
Tobias
TekniK
PostPosted: Sun Aug 09, 2009 2:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked then i can throw away all my expensives metal can CA3080A i specialy did buy for this project Sad (and mono-poly also)
pcp2020
PostPosted: Sun Aug 09, 2009 2:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
im super late on this one but when it happens I would be in for six
thanks for picking this one up Fonik
