Velocity and aftertouch adjustments...
Page 1 of 1 [6 Posts]
Audio files: 232
PostPosted: Sun Nov 28, 2004 10:13 am    Post subject: Velocity and aftertouch adjustments... Reply with quote  Mark this post and the followings unread
I wish there were adjustments for the velocity and aftertouch responses on the G2. I find that many of the patches I download need to be adjusted. I guess I have a relatively soft touch on the keyboard so I often multiply the velocity outputs by 1.1 or something. This seems to make the keyboard more responsive to me.
Rather than make this adjustmentment in each patch, it would be nice if one could make such an adjustment globally. The same for the aftertouch.
Tim Kleinert
G2 patch files: 236
PostPosted: Sun Nov 28, 2004 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I suggested to Clavia the very same feature for the NordLead3. It never happened.
Audio files: 232
PostPosted: Sun Nov 28, 2004 2:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
What's that they say about great minds? Idea
steampump
G2 patch files: 14
PostPosted: Sat Jan 29, 2005 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is there not a little confusion between range and response curve ? The reponse curve should normaly be defined by the master keyboard . I have 16 different curves for dynamic on my old Elka MK55 even negativ curves. And 8 curves for Aftertouch. Aftertouch can also be assined to other controlers like pitch, modweel, footcontrol,and volume. Ok i'm using the Engine, but
are the master keyboards functions of the G2 so bad ?
Artworks Music Computer
Audio files: 232
PostPosted: Sat Jan 29, 2005 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's not that the master keyboard functions are bad; there aren't any period.
PostPosted: Sat Jan 29, 2005 7:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Poly-aftertouch is invaluable for drum programming (since I play live into the sequencer) as well. I can't see this as being too difficult to implement on the G2...it goes along with the other voice-specific outputs. The keyboards might never have this, but the modules should absolutely support it.
Thank you for bringing this up!
