Buchla front panels
Page 1 of 1 [9 Posts]
frenchyinmunich
PostPosted: Thu Sep 10, 2009 1:52 am    Post subject: Buchla front panels Reply with quote  Mark this post and the followings unread
Hello,
I recently started to built few Buchla modules.
I never seen a Buchla in Europa during the last 25 years, since I am into electronic music playing.
I would like to associate to my boards the original front panel design.
If I would have the possibilty to have a Buchla just near my home, I would do the design myself with front panel design. Unfortunatly, I don't have one accessible and I don't know how to do the closest as possible...
Could someone help me? In giving some front panel design file or the exact dimension of the panels?
Does someone in Germany have one?
Best regards,
F
cbm
PostPosted: Thu Sep 10, 2009 2:57 am    Post subject: Reply with quote  Mark this post and the followings unread
4.25" x 7"
Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job)
TekniK
PostPosted: Thu Sep 10, 2009 4:56 am    Post subject: Reply with quote  Mark this post and the followings unread
i made a quad LPG design closely inspired by the original,its finished its in .ai file if u r interested.
frenchyinmunich
PostPosted: Thu Sep 10, 2009 6:07 am    Post subject: Buchla size front panels Reply with quote  Mark this post and the followings unread
Thanks a lot for your answer to both of you.
Well, I don't know where/what is the .ai file...
But I would be delighted to take a look to your design.
F
TekniK
PostPosted: Thu Sep 10, 2009 6:50 am    Post subject: Re: Buchla size front panels Reply with quote  Mark this post and the followings unread
F
http://www.electro-music.com/forum/topic-29016-350.html
.ai = file format from Adobe Illustrator.
u could also maybe ask user ericcoleridge here,he made some nice reproduction frontpanels.
magman
PostPosted: Thu Sep 10, 2009 7:21 am    Post subject: Reply with quote  Mark this post and the followings unread
There's a thread over on MuffWiggler that may be of interest:
http://www.muffwiggler.com/forum/topic-7169.html
There appear to be quite a few Serge Panel examples here.
Regards
Magman
zthee
PostPosted: Thu Sep 10, 2009 8:02 am    Post subject: Reply with quote  Mark this post and the followings unread
The biggest problem is still the font. Anyone know what font they used to use? I thought it was Folio, but that was wrong..
Peake
PostPosted: Thu Sep 10, 2009 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can buy pre-cut blank single-width panels directly from Buchla and Associates, and go from there.
http://www.buchla.com
julian
PostPosted: Sun Sep 13, 2009 4:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Depending on how obsessed you are with precision, there it the option of not bothering to redraw the panels at all...
If you can find a high resolution picture of what you are after, and then convert to 2 colour (black and white), retouch on a pixel by pixel level, and then scale you will get an exact reproduction.
This escapes any bother with font matching and the like.
Your dual colour .bmp (etc) can be used for screening, although converting to hplg (for import into .fpd) will not work (well, it will work, but i think itll result in outline work only)
For custom cnc engraved panels see - http://www.thebeast.co.uk/cnc/
