+12/-12 power supply for +15/-15 modules?
Page 1 of 1 [3 Posts]
SOTS
PostPosted: Mon Feb 15, 2010 8:23 pm    Post subject: +12/-12 power supply for +15/-15 modules? Reply with quote  Mark this post and the followings unread
hello!
new to the board and wasn't sure just were to post this. anyways, i'm planning to start work on a modular synth after some successful MFOS builds. i used a pre-built +/-12 volt power supply from futurlec for my first module, the noise cornucopia. the modular i'm planning to build will be mostly MFOS modules, but i also wanted to flexibility of adding some stuff from other sites, such as the bride chamber and cat girl synth. these two (as far as i can tell) both use +/- 15 power supplies. i was thinking about possibly build one using the MFOS design, but before doing that wanted to check and see if it would be possible to just use the +/-12 supply i have. i'm basing this loosely on the fact that MFOS designs can use either, though i realize that some modules require some alteration for +/- 15 volt. i'm hoping someone with more experience and knowledge can help me with this one. thanks!
RF
Audio files: 28
PostPosted: Mon Feb 15, 2010 9:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi SOTS -
Nice to have you here....
For what it's worth, I have a mixture of modules - Lots of MFOS & CGS a few from Ian Fritz, and various others from schematics I found around...
I've been running +- 12 Volts on all of it with no issues....
There may be some you will have to make some changes - but many of them just have changes if a few values to change voltages - many of them will work just fine on either...
good luck
bruce
www.sdiy.org/rfeng
SOTS
PostPosted: Wed Feb 17, 2010 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the info! it makes things a lot easier. if anyone has any other input on this, please feel free to let me know.
