SDS3 Single Voice PCB Run
Page 10 of 10 [245 Posts]
Goto page: Previous 1, 2, 3, ..., 8, 9, 10
mono-poly
PostPosted: Tue Feb 23, 2010 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
There is not a plan to do that.
It's now full modulare and you can have every channel to have an own modulator instead off one modulation buss on all 4 channels like the origional.
TekniK
PostPosted: Tue Feb 23, 2010 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok,then we all have to encourage Garret ,cross our fingers and just wait the time needed,no matter how long so that he
can get the best out of the project this topic started with, the high desired selfcontaining all on one pcb clone.
mono-poly
PostPosted: Tue Feb 23, 2010 9:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
This topic started with bubblechamber and he gave up.
mono-poly
PostPosted: Tue Feb 23, 2010 11:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
An option can be to have the boards made on one pcb.
So people can make it modular or pre-routed.
But then each voice will have a modulator on it's own and not shared like the orgional.
scriptstyle
PostPosted: Wed Feb 24, 2010 12:30 am    Post subject: Reply with quote  Mark this post and the followings unread
my hands are out of this project for now till time permits. i do think that this is a hard project to tackle do to the lack of correct information that is out there (documentation wise).
TekniK
PostPosted: Wed Feb 24, 2010 12:34 am    Post subject: Reply with quote  Mark this post and the followings unread
its not a big task to redraw everything tight on one board ,so if the version
from the guy that u know works well its already very positive.
mono-poly
PostPosted: Wed Feb 24, 2010 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks like you got a job Very Happy
TekniK
PostPosted: Wed Feb 24, 2010 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I only draw (and able to do) in single side,so for a commercial run its not
interesting.
vtl5c3
PostPosted: Sun Apr 04, 2010 8:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Does anyone have updated SDS3 schematics, or PCBs from Michael Buchner? I'd like to take a look at the docs, if it's ok to share them.
R.
jmejia
PostPosted: Thu Jun 24, 2010 4:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
what's the status of this project?
if you're looking for someone to do schematic capture in eagle - i'm happy to assist!
PostPosted: Thu Jun 24, 2010 11:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
obviously the schematics from michael are not public. otherwise they would have been published...
i once redraw the complete original schematic in eagle and even did a proto board (which wasn't working correctly) - i never have had the time to dive deep into it, and passed the board on to another member here in the forum.
jmejia
PostPosted: Fri Jun 25, 2010 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Matthias - if I understand the thread correctly - it looks like you broke the schematic out as a single channel.
Was that the board that was too large for free eagle? This schematic? http://www.modular.fonik.de/pdf/SDS3_sch.pdf
I am interest in making a single channel pcb - unless someone else is actively working on this.
I'm interested in picking this ball up if it's been dropped - but I don't want to step on anyone's toes.
Does it make sense for me to work from the schematic in that pdf? If it doesn't fit into free eagle - I might just break it into 2 pcbs.
mono-poly
PostPosted: Fri Jun 25, 2010 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
My tech got the docs and pcb's from Michael Buchner.
If we got a working module i'll talk with Michael about doing a pcb design.
I could use someone's help to put the single pcb's into one.
And from that point we can do a run.
We're working on it but it takes some time to get done.
jmejia
PostPosted: Fri Jun 25, 2010 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
ok mono - well ping me if there's something i can do to help! (specifically eagle/pcb layout)
mono-poly
PostPosted: Fri Jun 25, 2010 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok cool wil do.
Right now it's 3 different boards and wanna move that into one.
So people can build it full modular or prepatched.
scriptstyle
PostPosted: Tue Jul 13, 2010 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
glad someone is still putting some effort towards this! i am really looking forward to see what you guys come up with.
TekniK
PostPosted: Tue Jul 13, 2010 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes,am aswell still looking forward for the results of this project.
jmejia
PostPosted: Mon Apr 04, 2011 5:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bumping this thread. I'm happy to do some of the work to get this project going if possible... is anyone working on it right now?
xnor
PostPosted: Wed Apr 24, 2013 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Anything happening with this?
jmejia
PostPosted: Fri Apr 26, 2013 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
This thread has had a *little* more activity: http://electro-music.com/forum/topic-16985.html
At any rate - xnor and I are trying to get this up and running. Currently we have a semi working prototype based on Fonik's old work. If anyone has additional drawings, schematics, discoveries, tips - please share!
