Noisy 12dB SVF
Page 1 of 1 [2 Posts]
Paco
PostPosted: Tue Sep 28, 2010 8:51 am    Post subject: Noisy 12dB SVF Reply with quote  Mark this post and the followings unread
Hi
I built this module some time ago and I can hear a kind of pink noise at the outputs, specially with the cutoff widely opened. This was described before on this topic, and there are several workarounds without success:
http://electro-music.com/forum/viewtopic.php?highlight=noisy&t=18929
So it seems to be a common issue of this VCF. Did anybody find a solution? Any ideas?
Nothing is wrong on the PCB at first sight, and I have already replaced all the IC's but still the same.
I've also observed with an oscilloscope that the outputs are inverted, I get a sawtooth coming from the LP out while there is actually a ramp in the VCO. Is that the way it is supposed to behave?
Thanks in advance, I will keep on researching
synthmonger
PostPosted: Sun Oct 17, 2010 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd guess it's the LM13700. Those old OTAs can be a bit noisey when you're not feeding them hot signals.
Youtube!
modular demos!
Whacky tunes!
