The calculator!
Page 1 of 1 [11 Posts]
Calculator?
Hell yeah!
76%
 76%  [ 10 ]
Will it save time and effort?
7%
 7%  [ 1 ]
Will it make realy phat basslines?
0%
 0%  [ 0 ]
Real men don´t need no stinkin´calculator, I use Fortran.
7%
 7%  [ 1 ]
I wouldn´t use it.
0%
 0%  [ 0 ]
I wouldn´t use it but would keep it open to look smart.
0%
 0%  [ 0 ]
Kassen has finally lost his mind.
7%
 7%  [ 1 ]
Total Votes : 13
PostPosted: Wed Feb 09, 2005 7:34 am    Post subject: The calculator! Reply with quote  Mark this post and the followings unread
The recent discussion on building blocks reminded me of the old days with the classic. Up to version 2 the classic used to have building blocks, those were called "templates". They were below the "edit" tab and in hindsight must´ve been a good idea because the idea is now being revived. It was one of those touches that fell by the wayside because they weren´t too clear, and perhaps not everybody used them a lot. There was also a set of software settings to route the output busses to the physical outputs as you saw fit (nice for broken cables behind a rack with no time to spare) and......
...THE CALCULATOR!
The calculator was a marvelous little device. For those who forgot or those new to the scene; you would input (or import) the settings of a module and the amount of modulation it receves and out would roll a setting. This was very nice for a couple of reasons. For one thing you can get much finer controll over your parameters through the use of modulation but the interface does not display the end result; only the result of the settings of the module in question. It is also not at all easy to measure the output of every module, particularly where it concerns very fine osc tuning or dc offset due to the inacuracies of spectrumanalysis and the outputs being dc coupled. Admittedly trial, error and spare time can make up for a lot of what the calculator did but the calculator made it fast and easy, enabeling you to keep some semblance of workflow.
I keep a v2.0 next to my v3.03 of the clasic just for the calculator.
For this reason I want to petion for bringing back the calculator, updated for the year 2005 and the G2.
Vote Calculator, your children will thank you.
Do it now, don´t hesitate! No more testing in the dark!
Calculator for president!
cebec
G2 patch files: 31
PostPosted: Wed Feb 09, 2005 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi... is a pre 2.1 NM Editor available for download anywhere? i'd like to look at these 'templates' under the Edit tab...
The calculator does seem really cool. I'm looking at it in the NM 2.1 Editor, now. I voted to bring it back, updated, too.
PostPosted: Wed Feb 09, 2005 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
the default templates (three of them) are realy simple and not realy worth the download, just a simple standard 2osc synth and stuff. The idea was that you´d put your own in a certain dir. It worked a bit like copy-paste, except that you´d copy from a external patch that wasn´t realy "open" as such. I never used it back then, to be honest.
I have a copy of 2.0 that I´d send if you realy want it.
cebec
G2 patch files: 31
PostPosted: Wed Feb 09, 2005 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually, that sounds like something I could use. Currently, in order to add a building block/template to a patch i'm working on, I have to load the building block patch into an empty slot and copy/cut and paste to the active patch, which is annoying for several reasons.
I like this idea of an offline patchloader that's NOT one of the other slots.
Could you upload that 2.0 editor if it's not too much trouble?
Audio files: 232
PostPosted: Wed Feb 09, 2005 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
This poll was a difficult one for me. I was torn between the first and last options. After carefull consideration, I voted for option #1. The word "finally" in the last one seems unnecessary. Laughing
Seriously, I've never seen this calculator, but it sounds like a good idea.
PostPosted: Wed Feb 09, 2005 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, you can have a seperate poll on the topic of my mind and how I lost it. Please include the option that I didn´t realy lose it but left it behind intentionally to have a excuse to go back.
One of the first times I met up with Rob and Wout I asked where the calculator had gone. That got me some realy strange looks and the explanation that nobody ever used it. Since then I´ve blurted out "and the ruturn of the calculator!" at many sugestions of other new features but if we are going to have templates again, even informally, then we might as well bring back the calculator too, I think. We´ll call it a renesance after the calculator-less dark ages. I´ll get my rightfull place in history, much like the librarians of monastries in the dark ages ;¬).
Audio files: 232
PostPosted: Wed Feb 09, 2005 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Kassen, you don't seem like the Monk type of guy, but then again... Shocked
Audio files: 302
PostPosted: Wed Feb 09, 2005 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Kassen wrote:
One of the first times I met up with Rob and Wout I asked where the calculator had gone. That got me some realy strange looks and the explanation that nobody ever used it..
The idea of having a calculator was a good one, but also there was a good reason for not using it - one could never be sure of the meaning of the answers it gave.
What I'd realy wan tto have is a way to be able to calculate the effects of applying a signal and an attenuation on the parameter controlled. This doesn't necessarily need to have the form of a calculator, specifications alone would do for me.
To get things exactly right takes a lot of experimentation currently.
Jan.
PostPosted: Wed Feb 09, 2005 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I´m not sure I understand what you mean. It works perfectly fine for me.
Yes, agreed, that´s the main thing. I´d like to place the aditional remark that it would be very nice to be able to figure out exactly what value will come out of the waveshapers for a speciffic input given the settings, mode, mod.index and modulation input. The waveshapers are brilliant for c.v. manipulation but hard to use within larger structures due to a lack of documentation. Setting one right isn´t so bad but if there are several that somehow relate to the same structure then it becomes a pain.
Audio files: 302
PostPosted: Wed Feb 09, 2005 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've always found it to be a rather mystical instrument although I did try to use it.
Maybe it was a simple matter of garbage in / garbage out then :-)
Jan.
PostPosted: Wed Feb 09, 2005 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, yes, back in 2.0 It was all chicken bones and incantations to me too! It´s just that as the Nord and my knowledge of it matured the need for one grew untill I finally sat down and figured out how to work it. Importing values from patches and so on is still voodoo for me but that´s perhaps because I don´t actually use 2.0 to run my modular and so it never actually runs a patch from which to import anything.
For simple things like making sure your osc. is tuned as exactly as it can be it´s a wonderfull tool though. You have to be carefull because for some parameters it can output values expressed both in time and Hz but that´s a good thing, not a problem.
If clavia still believes it´s too confusing and will turn new users off then I´d already be very happy with a stand alone program, a "assistant" if you wish. Perhaps some kind soul would give such a thing a go himself but it would be hard to get all of the exact values. From time to time only the *exact* value is good enough and Clavia isn´t realy generous with data on the exact algorithems used for everything (and understandabley so).
