Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Fri Dec 10, 2010 10:39 am Post subject:
A hidden synthesizer into the NordLead and NordLead2 Subject description: An easter egg! |
There is a complete different synthesizer implemented into the NordLead and NordLead2, and their Rack versions, of course.
NOT into the NordLead2X and NordRack2X...
http://nm-archives.electro-music.com/020_NordLead2/Red_Lady/Index_bestanden/Red_Lady/Synthese_methods.htm
and click the link Hidden Synthesizer
Beware: the output is very loud, so protect your ears by controlling the volume usin a mixing desk!
Have fun and hopefully return o this forum with questions, remarks and results...
The special mode is not completely finished and there is no documentation nor Manual.
Read the text first and listen to the sound examples.
Merry Christmas!
Wout Last edited by Wout Blommers on Sun Dec 12, 2010 3:48 am; edited 1 time in total |
dorremifasol
Joined: Sep 28, 2006 Posts: 823 Location: Barcelona, Spain
G2 patch files: 49
Posted: Sat Dec 11, 2010 11:49 am Post subject:
This is ultra-cool Wout, thanks for the info
Now where can I find a cheap Nord Rack 2... _________________ Cheers,
Albert |
Wout Blommers
Audio files: 123
G2 patch files: 12
GriZZly
Posted: Sun Dec 12, 2010 8:05 am Post subject:
Hey there,
I was reading that article and thought, hey isn't that my post?
I'm glad you found this out, this sure is awesome
I'll definately try this out too.
But is there really no one who can tell what the knobs etc. exactly are? I mean not even the people from clavia knew this anymore?
Cheers, _________________ -GriZZly |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Dec 12, 2010 9:36 am Post subject:
| GriZZly wrote: | | ... I mean not even the people from clavia knew this anymore? | No one...
Wout |
ricard
Posted: Wed Jan 05, 2011 2:46 pm Post subject:
The person who wrote the firmware inside the Nord Lead 1 and 2 (Peter Jubel, aka "Pelle") now works for Propellerhead software. Another Propellerhead employee who happens to be on an email list that I frequent asked Pelle if he remembered anything about it; even had a Nord Lead in the office so that they could play with it. Unfortunately Pelle didn't remember anything in particular about the mode (don't forget the Nord Lead firmware was written 15 years ago!), not even how to get into the mode, except that it was some form of string synthesis method. (Karplus-Strong comes to mind, but I don't know if the Nord Lead mode is related to it.)
He did recall however that there were two sub modes, one 'plucked', and one 'bowed' (where the mod wheel would function as the bow of a violin), but could not remember how to switch between the two.
After a little experimentation, I determined that the LFO2 DEST (ARP.TYPE) button toggles between the modes, in that in 'plucked' mode a small 'chirp' or 'click' is inserted at the beginning of the sound. It's not always noticeable though; it probably depends on a combination of the other parameters. (Note that the LEDs don't change when the button is pressed in this mode, so you'd be forgiven for thinking that nothing is happening).
All in all, the synth behaves very weirdly in this mode (tried on my Nord Lead 2), very uncontrollable at times. I wonder if it works slightly differently on the Nord Lead 1; I would assume that it was implemented on the '1, and then just remained in the firmware when the '2 was made, so it could be that it doesn't match any changes made in hardware between the '1 and the '2. All pure speculation on my part.
/Ricard |
Posted: Wed Jan 05, 2011 4:19 pm Post subject:
No offence Wout, but wouldn't it just be better to buy a Nord Modular instead? It would be more musical!  _________________ ACHTUNG!
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Jan 06, 2011 2:02 am Post subject:
ricard!
| ricard wrote: | | ... After a little experimentation, I determined that the LFO2 DEST (ARP.TYPE) button toggles between the modes, in that in 'plucked' mode a small 'chirp' or 'click' is inserted at the beginning of the sound. It's not always noticeable though; it probably depends on a combination of the other parameters. (Note that the LEDs don't change when the button is pressed in this mode, so you'd be forgiven for thinking that nothing is happening). ... | That's great info.
Wout |
BoBSwanS
Joined: May 08, 2011 Posts: 4 Location: Manchester Uk
Posted: Sun May 08, 2011 7:24 am Post subject:
| Amazing! |
Rokatansky
Posted: Wed Aug 06, 2014 6:17 pm Post subject:
I forgot how to enter in this mode?
Could somebody please remind me?
TIA |
Joined: Apr 24, 2009 Posts: 2519 Location: Bristol UK
Audio files: 505
Posted: Thu Aug 07, 2014 3:03 am Post subject:
| Wout Blommers wrote: | | First you have to enter Pelle’s year of birth: 1965. Set Slot A to Program 19 and Slot B to Program 65. Only the numbers will do, so never mind if memory location 19 is holding another Program than the factory preset. Than press and hold the Portamento Auto button, after which you press and hold the Shift button (what else). Holding both press the Velocity/Morph button and release it again. Still holding the two first buttons press the Performance button and you will hear a click, which means the Pelle mode is active. |
Edit: correction _________________ Muied Lumens Sub Forum
Bandcamp Last edited by robsol on Thu Aug 07, 2014 5:41 am; edited 1 time in total |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Aug 07, 2014 4:38 am Post subject:
| Muied Lumens wrote: | | Wout Blommers wrote: | | First you have to enter Pelle’s year of birth: 1965. Set Slot A to Program 19 and Slot B to Program 65. Only the numbers will do, so never mind if memory location 19 is holding another Program than the factory preset. Than press and hold the Portamento Auto button, after which you press and hold the Shift button (what else). Holding both press the Velocity/Morph button and release it again. Still holding the two first knobs press the Performance button and you will hear a click, which means the Pelle mode is active. |
Just saw a small mistake: knobs should be buttons, ofcourse...
Wout |
Audio files: 505
Posted: Thu Aug 07, 2014 5:43 am Post subject:
Ah of course. I have edited my post.
Hope you don't mind that I copied this over from the Nord Users forum. _________________ Muied Lumens Sub Forum
Bandcamp |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Aug 07, 2014 9:15 am Post subject:
Not at all!
It's all about information, isn't it? |
Rokatansky
Posted: Thu Aug 07, 2014 10:13 pm Post subject:
Regards |
W.T.
Joined: Jul 11, 2004 Posts: 272 Location: The Netherlands
G2 patch files: 11
Posted: Fri May 29, 2015 6:13 am Post subject:
I would like to try it out on my NR 1.
Is there any danger or change I could "destroy" my beloved NR by
doing this. Ever happen to anyone who try out pelle's mod?
thanks!
sorry for bad English im tired and a bit sick at the mo. _________________ Clavia stuff that I use : expanded Nord rack & NM G2 engine. |
waveguide_chronicles
Posted: Wed Sep 06, 2023 1:57 pm Post subject:
| GriZZly wrote: | | But is there really no one who can tell what the knobs etc. exactly are? |
Well... almost no one. 😉 https://soundcloud.com/pelle-mode |
xjscott
Posted: Mon Sep 11, 2023 7:10 pm Post subject:
| Thanks for this post. Worth the wait. |
John_W_Thompson
G2 patch files: 5
Posted: Sun Feb 11, 2024 10:57 am Post subject:
| Will this work on Discovery Pro? |
