Let's see your Lunetta!
Page 13 of 22 [526 Posts]
Goto page: Previous 1, 2, 3, ..., 11, 12, 13, 14, 15, ..., 20, 21, 22 Next
Audio files: 228
PostPosted: Thu Dec 09, 2010 1:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Great job! Nice video. Try controlling the up/down with a logic signal too. Very Happy
droffset
PostPosted: Thu Dec 09, 2010 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
textual wrote:
very cool! love the backwards feature.. you have a schematic yet?
Not really a schematic, but there's a diagram of how things are connected here:
http://www.flickr.com/photos/droffset/5025001501/
Mosc, Thanks for the idea, I think there's enough space to place a patch point. Smile
Edit: Spelling mistakes.
sndbyte
PostPosted: Sun Feb 13, 2011 10:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just finished my most recent noise maker tonight. I'll take a photo tomorrow (the panel is drying), but here is a scan of the layout.
 Filesize:  1.88 MB
 Viewed:  1903 Time(s)
sndbyte
PostPosted: Mon Feb 14, 2011 7:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here are some photos of my latest box. I made it using a pcb that I painted with black spray paint. The box is a wooden cigar box painted with hammered metal spray paint. There are 6 piezo discs mounted to the bottom of the box under the pcb so you can listen to them or you can use the fixed resister mixer and listen over an amp using the output jack.
 Filesize:  337 KB
 Viewed:  1715 Time(s)
 Filesize:  358.44 KB
 Viewed:  1836 Time(s)
 Filesize:  453.83 KB
 Viewed:  1817 Time(s)
 Filesize:  411.16 KB
 Viewed:  609 Time(s)
clarke68
PostPosted: Mon Feb 14, 2011 10:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well that is an inspiring build!
Can you post a vid so we hear it too?
Great job!
tjookum
Audio files: 26
PostPosted: Tue Feb 15, 2011 1:24 am    Post subject: Reply with quote  Mark this post and the followings unread
beautifull craftsmanship!
I already liked the look of your pervious two but this one looks even cleaner. And I agree on the video, sound and blinkin lights!
Hunter S. Thompson
movies
noise
Psyingo
PostPosted: Tue Feb 15, 2011 6:27 am    Post subject: Reply with quote  Mark this post and the followings unread
cool design, bro
Audio files: 228
PostPosted: Tue Feb 15, 2011 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
sndbyte: wow!
sndbyte
PostPosted: Wed Feb 16, 2011 7:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a quick video demonstration of the XOR 4070 noise chain. The audio is a bit low so you might want to use headphones (first time I shot a video with this camera... the volume kicks in around the 1 minute mark).
Anyhow, here is my brief description:
Noise circuit made using a CMOS 4070 XOR gate IC. There are 2 inputs to the circuit and 10 outputs with red LEDs. The inputs are driven by 2 squarewave oscillators (made using a 40106 IC). 6 of the outputs are sent to a passive resistor mixer and then to a small amp.
sndbyte
PostPosted: Wed Feb 16, 2011 7:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is no amp in this video, just 2 piezo discs, so use headphones.
2 LFOs made with a 4069 CMOS IC. One is driving a photocell which is connected to a 40106 oscillator. This is then gated using a 4066 CMOS analogue switching IC (the other LFO is controlling the gate). The output is then sent to 2 piezo discs which is why the volume is so low.
RF
Audio files: 28
PostPosted: Wed Feb 16, 2011 8:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is really a beautiful build! Amazing work!
bruce
www.sdiy.org/rfeng
Repeater
PostPosted: Sat Mar 19, 2011 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Former lurker coming out of the shadows. I wish I had found this forum a couple years ago when I started doing this stuff. I've made a bunch of CMOS oscillators (*yawn*) and noise boxes. I've yet to build anything really complicated, but I'm starting to get ideas for a big patchable CD4000 synth. Anyways, here's my most recent build:
It's my take on the Bug Brand Board Weevil. Three 40106 square waves with switchable hi/lo range and psuedo sync run into two XOR ring mods with a pot to blend between the two XOR outputs. The red things at the bottom are body contacts. The big knob is voltage starve. Twisted Evil
a clip: http://soundcloud.com/martin-freem/touchsynth
Then there's this guy:
4 4093 oscillators split into stereo pairs and a stereo panner built with a 40106 and homemade vactrols. When you patch one channel of the panner into the other channel, it works like a primitive envelope generator/vca (no idea why this works, but it does). Here's a clip: http://soundcloud.com/martin-freem/growler-v2
I put other builds up on my blog sometimes: www.hellospiral.tumblr.com
Draal
PostPosted: Sun Mar 20, 2011 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Great looking Dirty Bomb there sndbyte Very Happy ! I have to spend little more time and see what you put in that case. Very slick design.
And Repeater - Welcome aboard Exclamation Thanks for sharing your sounds and pics. Looking forward to seeing what you come up with in the near future.
Zontar Prevails!
sndbyte
PostPosted: Sun Mar 20, 2011 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I don't think I'd ever take one of my little noise making machines on an airplane. I imagine security would have a lot of questions!
Psyingo
PostPosted: Sun Mar 20, 2011 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
i actually brought one of my diy-synths on a plane from the USA to europe and before i went through security i said "look i have this synth thing in my backpack, should i take it out?" the security guard said "no its fine". then when i went through the baggage xray the operator got all flustered and said "we have a problem here!" i was waiting for her to say something like "looks like a weapon"... but she then said "looks like a... uhh.. uhh... video game system or something?" lol. they opened the bag "what is this thing?!" "it's a synth i build" "oh... uh alright, you're clear."
moral? you might get funny looks coming from the USA. When i came in to germany they didnt ask about it, when i left they said "is this yours? ok." and when i got back into the states they didnt say anythign again...
droffset
PostPosted: Sun Mar 20, 2011 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great work you guys, thanks for sharing!
Repeater
PostPosted: Sun Mar 27, 2011 9:07 am    Post subject: Reply with quote  Mark this post and the followings unread
another not-quite Lunetta from me:
It's a clock/divider (40106/4040). Each toggle switch turns on a division (0-5 octaves down). Then there's a range rotary switch (220uf/47uf/10uf/.1uf) for the timing capacitor on the 40106.
Here's a clip of it running into the Frequency CV input of a self-oscillator filter: http://soundcloud.com/martin-freem/clockdivider
Why even bother with a step sequencer? My big Lunetta project will definitely include a pair of these things.
Anyone know how to add a CV input to the 40106 clock itself? I've read that negative voltages fry CMOS and I'd like to be able to get it to receive signals from my modular synth without the risk of burnout. Maybe just adding a squared up audio input is a better option?
Audio files: 228
PostPosted: Sun Mar 27, 2011 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Repeater: welcome to electro-music.com - great to have you here.
Neat looking synths you have there.
tjookum
Audio files: 26
PostPosted: Mon Mar 28, 2011 2:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice sounds there repeater, welcome to the wonderfull world of lunetta synth making.
As for the 40106 CV input, you are right about it not accepting negative voltages. If you have a positive voltage you can use the YAVCO:
http://electro-music.com/forum/post-241976.html
Hunter S. Thompson
movies
noise
Repeater
PostPosted: Mon Mar 28, 2011 6:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, great idea. I suspect that if you split the voltage to other 40106s and mess with the resistor in between pins 1 and 2 on each 40106 and the timing capacitors, you can get harmonized oscillators.
goat destroyer
PostPosted: Thu Mar 31, 2011 6:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here are my two successful Lunettas based off of a combination of Hetrodyne Space Explorer, Cacaphonator and Nick Collins stuff. I love these things.
these are some multitrack compositions with alot of echo and delay
http://www.stearnsdog.com/Negatron_E45105.mp3
http://www.stearnsdog.com/Negatron5000_SpaceSong1.mp3
Draal
PostPosted: Fri Apr 01, 2011 7:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Really diggin' the look goat! Cool
Zontar Prevails!
Team Toothpaste
PostPosted: Sat Apr 02, 2011 2:35 am    Post subject: Some CMOS things Reply with quote  Mark this post and the followings unread
hey everyone, here's a likn to a pile of CMOS stuff I built with somehelp from this site. thanks to all of you for the helpful articles and forums and things
http://www.youtube.com/user/TeamToothpaste
 Filesize:  1.05 MB
 Viewed:  1568 Time(s)
Audio files: 228
PostPosted: Sun Apr 03, 2011 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Goat Destroyer and Team Toothpaste. Great pics. Thanks for sharing. I dig these contraptions. Very Happy
Team Toothpaste
PostPosted: Mon Apr 04, 2011 2:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks mosc! as we all know a picture speaks a thousand words, and a video is made of thousands of pictures! meant to say there's a few video's on you tube, here's my favorite
http://www.youtube.com/watch?v=mFTS-LuLG-4&feature=related
i love this thing. thinking about how to make it slightly more rugged.
sndbyte - your aesthetic is beautiful, the sounds are nice and crunchy too. does it also have an output jack?
