Is it possible to control Master Clock from a module?
Page 1 of 1 [10 Posts]
xav
G2 patch files: 7
PostPosted: Fri Mar 11, 2011 12:31 pm    Post subject: Is it possible to control Master Clock from a module? Reply with quote  Mark this post and the followings unread
Hi everybody,
Does anybody know if it is possible to control the tempo and the Start/Stop button of the Master Clock Module, from a midi control module? (not from an external device connected to midi in port)
CC80 doesn't seem to control the tempo, and I couldn't manage to sent CC80 information from a module to the Global Midi Channel.
I wish I could improve that patch to control the Master Clock:
http://electro-music.com/forum/topic-46945.html
Thank for your help
fac
PostPosted: Fri Mar 11, 2011 8:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why use the Master Clock at all? Maybe you could use a pulse LFO or something?
My music: http://cdbaby.com/all/fac
seb
PostPosted: Sat Mar 12, 2011 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi xav,
I have a small self-built MIDI router connected to the in/out. What I do is sending CC80 out to MIDI channel 1 (which is my global channel) and configured the router to send it back to the G2. So it is possible to start and stop the master clock using a MIDI ctrl send module.
If your G2 is not connected to another device you could try to plug in a MIDI cable from out to in and disable all local midi sends (otherwise you will play each note twice because the keyboard sends MIDI to itself).
best,
seb
http://www.myspace.com/sebastianarnold
xav
G2 patch files: 7
PostPosted: Wed Mar 16, 2011 8:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Seb and Fac.
I didn't dare plug a midi cable because of bad experiences somebody reported in this forum (frozen G2).
Why use a Master Clock Module? Because it is so useful to sync everything in 4 slots without complex repatching and using the buses.
If a midi connection is required, I will look for an Iphone soft that sends midi clock and has a tap tempo functionality... Does anyone know something like that?
gomidas
G2 patch files: 6
PostPosted: Thu Mar 17, 2011 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Funbox 2 can do it > http://syntheticbits.com/funkbox.html
read manual for instructions >
http://syntheticbits.com/FunkboxManual/FunkboxManual-8.html
maybe some other apps can do that too, I'm gonna try with my midi mobilizer and see if it's tight enough for the G2 ( G2 LOVES TIGHT MIDI CLOCK!.. )
gomidas
G2 patch files: 6
PostPosted: Thu Mar 17, 2011 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
this looks good also but i can't see TAP TEMPO...
Backline MIDI
http://www.audiofile-engineering.com/backlinemobile/forums.html?page=Backline%20MIDI
As you don't use computer in live situation I assume u already have the great MIDI MOBILIZER Wink
xav
G2 patch files: 7
PostPosted: Fri Mar 18, 2011 11:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Gomidas,
The Funkbox seems nice. I gonna buy a MIDI MOBILIZER... I wanted to do everything with the G2... but an external master clock is so useful...
Tim Kleinert
G2 patch files: 236
PostPosted: Sat Mar 19, 2011 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a MIDI-clock-generating footswitch pedal:
http://www.ploytec.com/34oneII/
Kaan
PostPosted: Sun Mar 20, 2011 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Although G2 receives the tempo change messages from my midi keyboard, CC80 doesn't seem to control the Run/Stop button and I couldn't manage to sent CC 80 information from a module to the Global Midi Channel either.
Edit: I solved it. The buttons didn't respond to CC 80 command, but rotary responded well! Now I definitely don't need G2 keyboard anymore Very Happy
Kaan
http://soundcloud.com/phosphene-1
xav
G2 patch files: 7
PostPosted: Mon Mar 21, 2011 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Tim, I didn't know this one.
