today> Various Artists September equinox Concert
Vocoder concept - crazy idea really
Page 1 of 1 [22 Posts]
frequencycentral
PostPosted: Tue Oct 04, 2011 10:32 am    Post subject: Vocoder concept - crazy idea really Reply with quote  Mark this post and the followings unread
Ok, so recently I've been thinking about building/designing a minimum vocoder. My original idea was to make it managable by using a minimum number of bands, maybe as few a 4. But today I had a crazy idea........instead of multiple fixed BPFs, multiple envelope followers and VCAs........how about a multiplexing vocoder? So, only two BPFs, one carrier and one modulator - but they are both voltage controlled and swept simultaneously through the same frequency ranges by an oscillator. The oscillator would have to be running pretty fast to get any sort of useable 'sample rate' though. Here's a block diagram:
....all you have to decide is how fast the LFO needs to run to get to a workable resolution. In fact it won't be an LFO really, it'll have to be at least at the lower end of the audio range. Here's the rub - at those frequencies, the oscillator is certainly going to 'bleed' into the vocoder's audio path. I have used audio frequency oscillators as control voltages into VCFs on my modular system - the result is FM, which is not desirable here. So, any way to 'null' the oscillator? Maybe stick it through an inverter and mix the output into the audio path so that phase cancellation obliterates the bleed?
Hmmm, maybe it's actually a cross between a vocoder and a sample rate reducer? Anyway, if the challenges can be overcome it could be built with a couple of LM13700 and maybe a dozen opamps.
emdot_ambient
PostPosted: Tue Oct 04, 2011 12:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have no clue what that would end up actually sounding like but...give it a try!
And remember, audio samples or it didn't happen Wink
Mongo1
PostPosted: Tue Oct 04, 2011 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure what that's going to sound like, but it's not going to be a vocoder.
You're sort of trying to do what is done in a DSP, processing multiple bands with a single signal chain. The thing is, a DSP can keep track of the context of each band separately. When it needs to sample the 1K band, it pulls out a bunch of context values, does the calculation, stores the output, and then stores the context for later. It then pulls the context info up for 2K (or whatever) and does it again. It can do that simply because it's fast enough and smart enough to keep everything separate.
Doing that with audio components won't work. There's no good way to keep all the information separate, so what you'll end up with is kind of a mush of information. I suspect it will sort of be a mix of the audio signal and the LFO frequency.
Sorry to pee in your chile.
Gary
Clack
PostPosted: Tue Oct 04, 2011 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Its a good idea, I love minimizing
I imagine some kind of ringing would be impossible to avoid if the LFO is at audio rate, you cant subtract it because it will not be at the same frequency because modulation creates sidebands. Also I think a vocoder needs to have all bands on at the same time?
Would it not be possible to do it at above audio frequency? say 10x so it samples the highest possible sound 10 times in a cycle - the only problem is can BPF's sweep that fast? all sorts of phase problems?
Maybe look into switching filters? binary controlled filters? MHz switching between frequencies?
Why don't you look into making a channel as cheap as possible? FET VCA? CMOS inverter band pass filter?
Clacktronics.co.uk
PostPosted: Tue Oct 04, 2011 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
what about fixed CV values above audio rate? i.e. using a DAC?
[edit]: i don't care how you will call it! vocoder or not, that does not matter at all. try your idea and see where it gets you (and us, of course)....
emdot_ambient
PostPosted: Tue Oct 04, 2011 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Clack wrote:
...all sorts of phreaky phase possibilities...
There, fixed that for you.
It won't be a vocoder but it might be interesting!
frequencycentral
PostPosted: Tue Oct 04, 2011 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah! The oscillator - too slow and nothing meaningful will happen, too fast and the filters won't have time to react. Then there's the bleed through to address. Certainly won't be a classic vocoder by any stretch, but I'm intruiged as to what sounds it might offer. Maybe have the LFO drive a LM3914 to generate 10 stepped CVs instead of a continuous stream? The resolution would go down but the filters might have a fighting chance of keeping up. And maybe the bleed would be less obvious?
http://www.frequencycentral.co.uk/
PostPosted: Wed Oct 05, 2011 3:14 am    Post subject: Reply with quote  Mark this post and the followings unread
that's what i intended with the DAC actually. i am curious of your results...
yusynth
PostPosted: Wed Oct 05, 2011 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
What about this ? :
http://www.geofex.com/Article_Folders/sing-wah/sing-wah.htm
Yves
Mongo1
PostPosted: Wed Oct 05, 2011 5:04 am    Post subject: Reply with quote  Mark this post and the followings unread
What about this ? :
Now THAT looks interesting. Who's going to do those PC Boards and when can I get one? Razz
Gary
Paradigm X
PostPosted: Wed Oct 05, 2011 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.oldcrows.net/~patchell/vocalfilter/vocalfilter.html
also looks (and sounds) very cool, but a bit impenetrable, protype looks a monster!
PostPosted: Wed Oct 05, 2011 5:56 am    Post subject: Reply with quote  Mark this post and the followings unread
you built one? i did!
in fact i use it as a a triple multimode VCF resonator most of the time (nice filterbank). i read jim's description how to set it up as vowel filter, alas, this would be no fun for me!
that would be nice, also. and would be closer to an actual vocoder, i think.
Mongo1
PostPosted: Wed Oct 05, 2011 6:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Matthias - I just got drool all over my desk....
Gary
emdot_ambient
PostPosted: Wed Oct 05, 2011 9:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Mongo1 wrote:
What about this ? :
Gary
+1 Please
emdot_ambient
PostPosted: Wed Oct 05, 2011 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
No kidding. I saw that a while back on Matthias's web site. It's an awesome looking DIY job, too thumb up One of my favorite designs actually.
Paradigm X
PostPosted: Thu Oct 06, 2011 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Holy Schmidt, that thing looks incredible Shocked
Do you have an info page on your site? Could find one. Did you build that just from those hand drawn sketched schematics?
OMG.
Hail the Master
Mongo1
PostPosted: Fri Oct 07, 2011 9:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually, I think Matthias has a hollow tree full of elves that are responsible for some of this stuff. Either that or he's an alien. Nothing else makes sense.
Gary
LektroiD
PostPosted: Sun Oct 09, 2011 1:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Mongo1 wrote:
What about this ? :
Gary
+1 Please
+2 Wink
zthee
PostPosted: Mon Oct 10, 2011 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
yusynth wrote:
What about this ? :
It kinda looks like a simpler version of the Bi-N-Tic filter? At least it reminds me of it...
I like the original idea!
PostPosted: Wed Oct 12, 2011 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
OMG.
Hail the Master
thanks for the laurels.
no, jim patchell actually made the gerber file available on his oldcrow site. i just sent them to a PCB house... alas, i had to pay about 100 bucks for this PCB.
diablojoy
PostPosted: Wed Oct 12, 2011 9:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
for a single prototype I would say that isn't that bad a price
at all.
very nice work, as with all your modules always
extremely professional looking
ask where the hell am I
as good an answer as any
Paradigm X
PostPosted: Thu Oct 13, 2011 3:29 am    Post subject: Reply with quote  Mark this post and the followings unread
OMG.
Hail the Master
Cool man, it really is fantastic looking. Any audio samples floating around?
$100, while a lot, is still quite tempting, for such a unique bit of kit. Do you happen to still have the files ? Smile
