 Forum index » Instruments and Equipment » iOS - iPad/Phone/Pod etc » TC-11
TC-11 1.2 Update
Page 1 of 1 [6 Posts]
Bit Shape
PostPosted: Thu Jan 19, 2012 3:11 pm    Post subject: TC-11 1.2 Update Reply with quote  Mark this post and the followings unread
Any day now you should see the 1.2 update for TC-11 in your iPad's App Store. There were some big under-the-hood things that needed work, but it came together much faster than I expected. I'm happy to break the new features to you all here. There are two significant upgrades:
1 - Live Patch Preview
In the Patch view, you'll see a floating window that acts the same way as the Performance view. You can play while you edit parameters, change sequencer values, waveforms, the lot. Device motion works, so you can try out everything while you patch.
The Live Preview window can be moved anywhere on the screen, and snaps to the edges. When you want it out of the way, it docks to the right side of the view:
This is a *huge* improvement to patch editing. It should make the flow of creating a new patch much easier (and more fun)!
2 - Sequencer Rate as BPM
You can now view the rate of the Sequencer in beats per minute, with a multitude of subdivision rates. This should make the Rate parameter more accessible. You can still set it to Hz if that makes more sense for your patch.
There are some other small bug fixes and improvements, but I'm hoping that you all will enjoy these two upgrades. Let me know what you think!
Audio files: 232
PostPosted: Thu Jan 19, 2012 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looking forward to this. That little performance window will be a bit help, I'm sure.
PostPosted: Thu Jan 19, 2012 6:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great stuff!
Flickr
DES
PostPosted: Thu Jan 19, 2012 7:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Excellent! Very Happy
www.davesneed.com
PostPosted: Fri Jan 20, 2012 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh YES!
ACHTUNG!
PostPosted: Sat Jan 21, 2012 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
v1.2 update is now available in the Appstore!
ACHTUNG!
