today> Various Artists September equinox Concert
 Forum index » Instruments and Equipment » Linux as a music workstation
Somewhere between Live and Reason?
Page 1 of 1 [7 Posts]
jksuperstar
G2 patch files: 18
PostPosted: Fri Mar 11, 2005 9:04 am    Post subject: Somewhere between Live and Reason? Reply with quote  Mark this post and the followings unread
It's only at Beta 0.11, but looks very good. I'm in the middle of bringing this up...
Wired is composed of a Audio/MIDI sequencer and a rack based plugin system, which enables you to record your instruments and mix them with electronic effects/modules at the same time. The user interface of Wired has been designed to make it easy for professionals or beginners to compose music in a software based environment.
Wired targets the Linux operating system, and uses GTK and wxWidgets for the graphic interface. It supports the ALSA sound architecture and OSS for Audio and MIDI I/O.
The following parts of the project are already implemented :
- Wired
* Multitrack Audio playback and recording
* Multitrack Midi playback and recording
* Sequencer engine
* Sequencer editing
* Midi Editing
* Undo/Redo
* ALSA/OSS/Jack Audio support
* ALSA MIDI Input support
* Plugin system
* Rack view
* Sequencer view
* Dynamic Mixer console
* Transport panel
* Online help
* Import Wave and Midi files
* Reads AKAI CDs
- Plugins
* Loop Sampler
* Beatbox
* Sampler
* Low-pass filter
* Delay
http://bloodshed.net/wired/?sid=2
Screenshots:
http://bloodshed.net/wired/?sid=5
Audio files: 226
PostPosted: Fri Mar 11, 2005 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
This looks very promissing. Please keep us up to date as you get some experience with this. If these guys want a user or developer forum, please let them know they can have them on electro-music.com. Idea
jksuperstar
G2 patch files: 18
PostPosted: Fri Mar 11, 2005 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Howard (any anybody),
There is a Live CD distrobution called "Mediainlinux" (www.mediainlinux.org) which has Wired bundled. That will boot your system without installing linux, and give you an idea of how this works (as of the build date of mediainlinux).
To help, you might look into ALSA (the linux audio driver system) and Jack (Linux's version of Rewire). You'll need to know how those systems work to get sound properly. To help with that, "lspci", "lsusb" and "modprobe" are system utilities that help identify what hardware you have (on the pci or usb bus), and to load the appropriate drivers for it, if the automatic hardware detection doesn't detect your particular audio card. The windowing system this live CD uses is called "fluxbox", if you boot up and find yourself not knowing what to do next. That can be found here: [url]fluxbox.sourceforge.net[/url]
I have not run Wired on mediainlinux yet, because my hardware has limited support, and I have to do some heavy configuration. However, if you have a high-bandwidth connection, it only costs you the time to down load & burn an .ISO image to CD. The whole LiveCD thing is so cool.
Also, this liveCD has "FreeJ" and "EffectTV", real-time video programs (I know your interested in that!), and lots of other video goodies. The mediainlinux site lists only three or four video/audio programs, but the CD has hundreds (literally).
Audio files: 226
PostPosted: Fri Mar 11, 2005 6:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm so totally absorbed with the electro-music 2005 event that I can't take this course at this time. My soundcard it a MOTU 828 MKII and my MIDI interface is a Unitor8 on a serial port. I suspect these aren't the best choices for a quick and dirty Linux music box.
PostPosted: Sat Mar 12, 2005 5:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I think the 60 USD M-Audio 2496 Audiophile card is well supported. I have that card myself. I have installed it in one of the old macs I use for virtual instruments. It is pretty decent.
nescivi
PostPosted: Wed Mar 23, 2005 4:36 am    Post subject: Reply with quote  Mark this post and the followings unread
MOTU is not very nice. They don't want to give the Linux Audio developers details about their hardware, so the developers can't write a driver for it...
I don't know about the Unitor8...
Audio files: 226
PostPosted: Wed Mar 23, 2005 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I would probably build a new machine for a Linux musicbox, complete with more friendly audio card and midi interface.
