Psyingo
Posted: Sun May 13, 2012 3:37 pm Post subject:
| Paradigm X wrote: | | What are the power requirements? 15v too much? Cheers |
I use 12v but any voltage over the cmos range should be fine. sound will change depending on supply voltage, but it should work fine. I can test more thoroughly when i get the prototype. |
Paradigm X
Joined: Feb 15, 2011 Posts: 363 Location: Null and void
Posted: Mon May 14, 2012 1:56 am Post subject:
Hi
Sorry, not trying to tell you what to do but if you post at muffs youll also likely get a ton more enquiries, poss making it cheaper
Cheers, ben |
loydb
Joined: Feb 04, 2010 Posts: 393 Location: Providence, RI
Psyingo
Posted: Thu May 31, 2012 9:50 am Post subject:
UPDATE:
prototype pcb has been shipped. batch pcb says it will arrive in 5-28 days, hopefully its on the shorter side of things. |
magneticstripper
Joined: Jan 12, 2009 Posts: 25 Location: San Francisco
Posted: Thu May 31, 2012 2:36 pm Post subject:
| can i put in for 2? |
Psyingo
Posted: Mon Jun 11, 2012 11:00 am Post subject:
| Prototype pcb has arrived. I will populate soon to check for bugs n such. |
Psyingo
Posted: Mon Jun 11, 2012 9:21 pm Post subject:
Mikmo
Joined: Dec 01, 2005 Posts: 150 Location: Copenhagen - Denmark
Posted: Tue Jun 12, 2012 3:04 am Post subject:
Nice compact board _________________ Stay Cool
Mikael
http://www.mikmo.dk |
baudrate
Posted: Thu Jun 14, 2012 1:13 pm Post subject:
| I am defiantly interested in one of these! |
Mongo1
Posted: Fri Jun 15, 2012 5:58 am Post subject:
Can someone point me to some more info on this? Sound samples etc?
I'm definitely interested but would like to know a little more....
Thanks
Gary |
Psyingo
Posted: Fri Jun 15, 2012 9:31 am Post subject:
http://electro-music.com/forum/topic-52786.html
Here is a link to the modular drum machine that uses the same 4 drum voices. Read about the twin t drums in that post. There are some sound samples down the page.
I will write and post a construction manual once i get the board verified.
The drums are a classic twin t ringingfilter configuration, similar to old organ drum machines or even some the tr606 and tr808 sounds. The sounds can easily be triggered from a piezo or audio impulses, and of course triggers from modular synths, etc. but when triggering from a small signal source the Synth drum bend will not work.
The capacitor values are not fixed, but i will supply some values for various drum ranges. |
Mongo1
Posted: Fri Jun 15, 2012 4:18 pm Post subject:
Thanks - I'm definitely interested!
Gary |
Jampy
Posted: Thu Aug 16, 2012 1:07 pm Post subject:
| Are there any of these PCBs still available? |
schmelfhelp
Posted: Sun Aug 19, 2012 2:27 am Post subject:
I'm also wondering if there are any pcbs still available.  |
Draal
Joined: May 18, 2010 Posts: 308 Location: Oak Park, IL
Posted: Sun Aug 19, 2012 6:21 am Post subject:
My belief is that he just received the initial pcb's and was going to run some tests on em'. When a project is really ready, people tend to create an obvious new thread for taking orders/info, etc. _________________ Zontar Prevails! |
Psyingo
Posted: Sun Aug 19, 2012 12:28 pm Post subject:
| Yes, draal is right. I received the prototype pcb but there was an error so I've had to re order it. Ill let you know when it's easy. |
-minus-
Posted: Tue Aug 21, 2012 12:26 am Post subject:
| Hey, can you repost the sounds? I click on them in the original thread and get 404 Error. Thanks. Maybe post them here? |
textual
Joined: Dec 05, 2009 Posts: 78 Location: New York City
Psyingo
Posted: Mon Oct 22, 2012 9:46 am Post subject:
I am happy to announce that I have reordered the prototype PCBs.
Once i have the prototype tested i can start shipping these little guys out.
should be 2-4 weeks to arrive.
the price will be EDIT: 10$ a board +shipping. Last edited by Psyingo on Mon Mar 25, 2013 10:13 am; edited 1 time in total |
Psyingo
Psyingo
Posted: Wed Nov 21, 2012 10:49 am Post subject:
stiill waiting on the prototype pcbs...
would anyone be interested in buying a kit of components if i were to make one available? |
Psyingo
Posted: Fri Nov 30, 2012 1:35 pm Post subject:
here are some pictures of the pcbs. The first shows the top and bottom of the pcb, the second is populated with one voice tested.
Posted: Fri Nov 30, 2012 10:17 pm Post subject:
Interested in the PCB at a $10 or so price point, not a kit so much.
What are all the unused connections in the second photo?
Edit:DUR I see the $15 price now, that's just fine, still interested  Last edited by elmegil on Fri Nov 30, 2012 11:10 pm; edited 1 time in total |
Psyingo
Posted: Fri Nov 30, 2012 10:20 pm Post subject:
| elmegil wrote: | | What are all the unused connections in the second photo? |
The board is split up into quarters, the part that has the wires coming off is one quarter, or one drum. the other drums don't have any controls yet, so those unused connections are for pots and in/outs |
Draal
Posted: Sat Dec 01, 2012 3:17 pm Post subject:
I'd buy a kit on a heartbeat. But if not available, a pcb alone is ok. _________________ Zontar Prevails! |
