 Forum index » Instruments and Equipment » Kyma
Keeping Kyma Alive
Page 4 of 6 [128 Posts]
BobTheDog
PostPosted: Mon Aug 06, 2012 9:20 am    Post subject: Reply with quote  Mark this post and the followings unread
25 hours and still running......
How did your test go Jan, still running?
Audio files: 308
PostPosted: Mon Aug 06, 2012 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Last night I had like 70 hours on the clock ... didnt check this morning (was late for work Wink ). Will be home again soon ...
Audio files: 308
PostPosted: Mon Aug 06, 2012 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
96 hours now.
BobTheDog
PostPosted: Mon Aug 06, 2012 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I take it thats the longest you have seen then?
So it looks like either the audio or the network may be causing your issues.
Up to 30 hours here, everything seems fine so far....
Audio files: 308
PostPosted: Mon Aug 06, 2012 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah longest I ever saw, prolly will let it run a bit longer just to be sure.
Audio files: 308
PostPosted: Mon Aug 06, 2012 3:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
30 hours with the tc connected is something I never had I guess ...
Audio files: 308
PostPosted: Mon Aug 06, 2012 5:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
it now ran for 01:20:00 .. it cant even display it ran for 100+ hours Confused
BobTheDog
PostPosted: Mon Aug 06, 2012 10:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
You are pushing the envelope Jan!
38 hours here and chugging away still....
BobTheDog
PostPosted: Mon Aug 06, 2012 11:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also Jan how have you got your firewire linked up?
I Have:
Mac 800 -> Pacarana 800 (left port looking from back)
Pacarana 800 -> Konnekt 400
BobTheDog
PostPosted: Tue Aug 07, 2012 2:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Also can you type the following in the terminal and past the results here:
system_profiler SPFireWireDataType SPNetworkDataType
cheers
Andy
BobTheDog
PostPosted: Tue Aug 07, 2012 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
50 hours....
Audio files: 308
PostPosted: Tue Aug 07, 2012 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I have the same linkup, well not now, but when I have it Laughing
Yup, can do, but I have networking off on the Mac currently and not going to retype that all .. anything specific you would want to know?
118 hours now.
Audio files: 308
PostPosted: Tue Aug 07, 2012 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Firewire just shows pacarana, Network shows BlueTooth, Ethernet, Firewire, Airport, Bluetooth PAN - all being off as in having no IP address assigned to them.
Audio files: 308
PostPosted: Tue Aug 07, 2012 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I have an older XML dump, it then had the TC connected and WIFI was on ... http://bluehell.electro-music.com/small_stuff/labtobbe4.spx.xml those should be the only changes .. oh and some less software running now, but otherwise the same info seems to be in there too.
BobTheDog
PostPosted: Tue Aug 07, 2012 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
I Just weaned to look at some version numbers, but our OSes are so out of kilter it isn't much use Sad
One thing that might be worth trying is deleting your FW network device in System Preferences->Network although I am sure that is nothing to do with anything.
My guess is that mine is going to keep running here which doesn't help much!
I can keep it running till the weekend when I am going to have to move stuff around again.
I surpose you have to gradually re-introduce stuff till it stops working, it is a bit of a bugger it takes quite a time to fail for you, makes testing different setups a bit of a pain.
Audio files: 308
PostPosted: Tue Aug 07, 2012 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, that's what I will be doing Crying or Very sad
Anyway, thanks for trying it Andy, gives me hope it could actually work with the TC!
BobTheDog
PostPosted: Tue Aug 07, 2012 10:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
And I was wrong, Just got up and it looks dead, 58 hours on the clock. Front panel looks good and responds but I have no audio.
I will get a coffee and see whats going on....
BobTheDog
PostPosted: Tue Aug 07, 2012 11:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK here is what I see.
There is no sound.
The pacarana seems fine, the front panel is responding.
One of the DSP chips is at 44% so I would say it is still running the patch, the I/O % is rangineing between 20-75%, the case temp has dropped 1 degree from how it was when everything was working fine.
The VCS controls are working but the dice is not having any effect.
The DSP Status window is dead.
Kyma itself is responding and looks fine, I recycled memory and that worked.
Then I did the old CTRL/SHIFT Status to get the log and the "Please turn on or connect your Kyma signal processor" appeared, clicking on OK just brings this dialog back after a while.
After a while of doing this I got "The Pacarana is not responding Unhandled bus reset or a firewire error. (22)
So now I disconnect both firewire cables from the back of the pacarana and re-connect them. I set up the K48 from the front panel, At this point the kyma reconnects ok and the DSP figure goes down to 1% so it looks like it has been initialised in some way.
Now I try to get debug log again, it seems to be working on it……..
BobTheDog
PostPosted: Tue Aug 07, 2012 11:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Still got the spinning watch, got a feeling I am not getting a debug log out of this...
BobTheDog
PostPosted: Tue Aug 07, 2012 11:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Spoke too soon, got a log 8.5MB so looks good, I will contact Symbolic and send it to them mentioning your name.
BobTheDog
PostPosted: Tue Aug 07, 2012 11:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, email sent, I have included you on it.
Interestingly I can run the patch again after reconnecting the firewire cables, I did not have to power cycle!
Audio files: 308
PostPosted: Wed Aug 08, 2012 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not alone Laughing
BobTheDog
PostPosted: Wed Aug 08, 2012 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
If we both badger them we might get it sorted Smile
Audio files: 308
PostPosted: Wed Aug 08, 2012 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Meanwhile I got a message from symbolic sound that they stopped testing after 50 hours because they needed the computer for something else .. it looks like they are just finding me a silly fool to want this thing to be reliable over weeks instead of days.
BobTheDog
PostPosted: Wed Aug 08, 2012 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I have had no reply from them yet.
Did you get the email I sent them?
