G2 Editor OSX Yosemite compatibility
Page 1 of 1 [9 Posts]
Dt31
PostPosted: Fri Oct 17, 2014 7:20 am    Post subject: G2 Editor OSX Yosemite compatibility Reply with quote  Mark this post and the followings unread
Any idea if G2 Editor works with Mac OSX Yosemite?
Thanks
tagirov
PostPosted: Sun Oct 19, 2014 10:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Same question.
Anyone tried the editor under OSX 10.10.x?
Best regards, Ruslan Tagirov
W.T.
G2 patch files: 11
PostPosted: Mon Oct 20, 2014 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Good question indeed.
Now who will be the first to try it out? Smile
Clavia stuff that I use : expanded Nord rack & NM G2 engine.
keencurl
PostPosted: Fri Oct 24, 2014 3:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello!
Yesterday I won G2X - it's just a dream!
Installed Nord Modular G2 set Editor on Yosemite 10.10, everything works fine.
Who can share the template for G2 under Logic Pro X?
I can not deal with MIDI sync
Thanks in advance.
Dt31
PostPosted: Fri Oct 24, 2014 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you! I hope you enjoy your G2!
aMUSEd
PostPosted: Tue Oct 28, 2014 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was amazed when it still worked under Mavericks - they certainly built it to last.
http://fingermarks.co.uk/music.htm
zenke
PostPosted: Fri Feb 20, 2015 6:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Have others upgraded to Yosemite and still able to use the editor?
uyoyu
PostPosted: Fri Feb 20, 2015 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
No problems here !
tagirov
PostPosted: Sat Apr 11, 2015 11:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi. Just to keep this post up-to date.
I've finally upgraded to OS X 10.10.3 Yosemite from Mavericks.
The Nord Modular G2 Editor works fine so far.
