Volume pot on headphone amp
Page 1 of 1 [5 Posts]
creekree
PostPosted: Wed Aug 10, 2016 3:11 pm    Post subject: Volume pot on headphone amp
Subject description: on input or output?
Hi all,
I rcently bought a small headphone amp on Ebay:
http://store3.sure-electronics.com/2-x-150-mw-class-ab-headphone-amplifier-board-lm4881
I want to use it with my LXR drummachine, but it is far too loud.
There is no volume control on this thing, so I want to wire a stereo pot to tame the volume a bit.
Where would I preferably put such a pot - in the input side or on the output side?
sneakthief wrote:
Your square wave isn't loud enough.
PostPosted: Wed Aug 10, 2016 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Input side. The output side has some power which would need thoughts.
Assuming the thing is not noisy .. but when it is noisy - output side. But .. as there is some power that would need thoughts.
So input side basically, unless the thing is unacceptably noisy .. but then again .. best to get rid of it then.
creekree
PostPosted: Thu Aug 11, 2016 4:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks,
I will give it a try.
I dont expect it to have studio quality, I just need something that I can plug into the LXR, without the need to fire up the whole studio.
The LXR (obviously) does not have a headphone output, and no volume pot either.
Christian
creekree
PostPosted: Sat Aug 13, 2016 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, it worked perfectly. I am surprised about the amount of noise - there is none! If anybody needs an ultracheap headphone amp, I can recommend this one for your "quick and dirty" needs.
PostPosted: Sat Aug 13, 2016 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool
