Top Top
Posted: Tue Jan 17, 2017 3:25 pm Post subject:
Setting trigger threshold on CMOS logic gates? |
Let's say I want to convert a 4V pulse to a 12V one.
How do I set a CMOS gate to register an "on" state at +4V, even though the supply voltage is +12V? _________________ ∆ A.M.P. ESOTERIC ELECTRONICS ∆ |
Posted: Tue Jan 17, 2017 4:09 pm Post subject:
hmm from 4 to 12 is a bit much otherwise you might have been be able to get away with adding an offset voltage to the input with 2 resistors.
I haven't tried that though. Usually I add a transistor to the input (which also inverts but that can sometimes be useful) or you could use a comparator.
I am not familiar with the CD4504, looks interesting. _________________ "My perf, it's full of holes!"
Top Top
Posted: Tue Jan 17, 2017 4:18 pm Post subject:
| PHOBoS wrote: | hmm from 4 to 12 is a bit much otherwise you might have been be able to get away with adding an offset voltage to the input with 2 resistors.
I am not familiar with the CD4504, looks interesting. |
Well the actual scenario here is that I want to output a 13V clock from a machine that is otherwise running on 6V in order to sync it with other machines.
Adding an offset voltage to the input with two resistors - would that be one from + and one from gnd? _________________ ∆ A.M.P. ESOTERIC ELECTRONICS ∆ |
Posted: Tue Jan 17, 2017 5:54 pm Post subject:
hmm I'd need a bit more information. If it is running on 6V it would be pretty tricky to get 13v out. You'd need a voltage doubler and some
other things or at least get that voltage from somewhere. However, adding a circuit to inputs so they work on a lower voltage shouldn't
be too hard. Forget what I said about adding an offset voltage, you can't just simply add voltages together
I think a comparator made with a single opamp would probably be the easiest solution and you could use a trimpot to set the reference voltage
which would make it easy to calibrate. _________________ "My perf, it's full of holes!"
Top Top
Posted: Tue Jan 17, 2017 6:31 pm Post subject:
| PHOBoS wrote: | hmm I'd need a bit more information. If it is running on 6V it would be pretty tricky to get 13v out. You'd need a voltage doubler and some
which would make it easy to calibrate. |
The wall wart it is running on is at 18v and I am regulating the voltage of the main part of the machine to 6v with an LM317. The reason I am running at that voltage is that I tuned some twin t circuits to desired frequencies and don't want to redesign the whole circuit (it's already built on perf board).
I have a second regulator to provide the 13v for the clock output circuit. _________________ ∆ A.M.P. ESOTERIC ELECTRONICS ∆ |
Posted: Tue Jan 17, 2017 7:54 pm Post subject:
ah ok, if you already have the 13V available it is pretty easy to do with a comparator. Add your 6V clock signal to
the non-inverting input of an opamp, which you power with the 13V, and use a voltage divider (either 2 resistors or a
trimpot) to add a reference voltage of say 3V to the inverting input. If the clock signal is below this reference voltage
the output of the opamp will be 0V* and if it is above it the output will be 13V*.
*in reality it will a bit above 0V and below 13V depending on the used opamp _________________ "My perf, it's full of holes!"
