Setting trigger threshold on CMOS logic gates?
Page 1 of 1 [11 Posts]
Top Top
PostPosted: Tue Jan 17, 2017 3:25 pm    Post subject: Setting trigger threshold on CMOS logic gates? Reply with quote  Mark this post and the followings unread
Let's say I want to convert a 4V pulse to a 12V one.
How do I set a CMOS gate to register an "on" state at +4V, even though the supply voltage is +12V?
A.M.P. ESOTERIC ELECTRONICS
PostPosted: Tue Jan 17, 2017 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think the easiest way is to use a level shifter, these are ic's designed to do just that.
http://www.ti.com/lit/ds/schs369/schs369.pdf
PostPosted: Tue Jan 17, 2017 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmm from 4 to 12 is a bit much otherwise you might have been be able to get away with adding an offset voltage to the input with 2 resistors.
I haven't tried that though. Usually I add a transistor to the input (which also inverts but that can sometimes be useful) or you could use a comparator.
I am not familiar with the CD4504, looks interesting.
Top Top
PostPosted: Tue Jan 17, 2017 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well the actual scenario here is that I want to output a 13V clock from a machine that is otherwise running on 6V in order to sync it with other machines.
Adding an offset voltage to the input with two resistors - would that be one from + and one from gnd?
PostPosted: Tue Jan 17, 2017 5:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmm I'd need a bit more information. If it is running on 6V it would be pretty tricky to get 13v out. You'd need a voltage doubler and some
other things or at least get that voltage from somewhere. However, adding a circuit to inputs so they work on a lower voltage shouldn't
be too hard. Forget what I said about adding an offset voltage, you can't just simply add voltages together doh
I think a comparator made with a single opamp would probably be the easiest solution and you could use a trimpot to set the reference voltage
which would make it easy to calibrate.
Top Top
PostPosted: Tue Jan 17, 2017 6:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
The wall wart it is running on is at 18v and I am regulating the voltage of the main part of the machine to 6v with an LM317. The reason I am running at that voltage is that I tuned some twin t circuits to desired frequencies and don't want to redesign the whole circuit (it's already built on perf board).
I have a second regulator to provide the 13v for the clock output circuit.
PostPosted: Tue Jan 17, 2017 7:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
ah ok, if you already have the 13V available it is pretty easy to do with a comparator. Add your 6V clock signal to
the non-inverting input of an opamp, which you power with the 13V, and use a voltage divider (either 2 resistors or a
trimpot) to add a reference voltage of say 3V to the inverting input. If the clock signal is below this reference voltage
the output of the opamp will be 0V* and if it is above it the output will be 13V*.
*in reality it will a bit above 0V and below 13V depending on the used opamp
PostPosted: Tue Jan 17, 2017 11:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you prefer to use an opamp, why not use it as a Schmitt trigger?
Just one more resistor as in a comparator and, especialy when your edges of your signal aren't fast, are less succeptible to noise.
http://neurophysics.ucsd.edu/courses/physics_120/AoE_Comparators.pdf
PostPosted: Wed Jan 18, 2017 3:36 am    Post subject: Reply with quote  Mark this post and the followings unread
As far as I am aware turning it into a schmitt trigger by adding hysteresis only works if you swap the inputs and then it inverts.
Since the signal is already digital (and I assume we are not talking about very high speeds here) I don't think it is needed anyway.
PostPosted: Wed Jan 18, 2017 5:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Non-inverting schmitttrigger, bron: https://ocw.mit.edu/courses/electrical-engineering-and-computer-science/6-071j-introduction-to-electronics-signals-and-measurement-spring-2006/lecture-notes/24_op_amps3.pdf
Drawback is this has a hysteresis around gnd level, so would you want to use it, there will be a need for a voltage source.
 Filesize:  26.62 KB
 Viewed:  370 Time(s)
PostPosted: Wed Jan 18, 2017 7:17 am    Post subject: Reply with quote  Mark this post and the followings unread
oh nice, I'm not sure if I have seen that before. It does make sense though to just add the feedback to the input signal.
